Thread: Lower Intake Manifold Leak
Results 1 to 18 of 18
  1. #1 Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Hi my name is P Malone and I have a 2002 Grand Prix SE 3.1L. What my problem is the old intake manifold had a crack in the third cyclinder. So I replaced the old intake manifold with a new one and gasket set. When I started the car I notice some coolant leaking. The New gasket set came with some sealant. I put some of the sealant around the front end of the intake manifold near where the power steering pump blocks the two end bolts, and at the other side near where the thermostat is. Did I do something wrong? Or was it that I have to put the sealant around the openings and edges of the manifold gasket set except for the upper air intake? I also have one last question, how do I bleed the air out of the coolant system so my heat works. Any help would be appreciated.
  2. #2 Re: Lower Intake Manifold Leak
    The rtv goes in the corners of the lim. You may have to tear it back down and fix it.
  3. #3 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Dsmuts what about the coolant Ports. Do they need rtv around them too? Because when I had to clean the old gasket off it seem like their was rtv on where the old seal was.
  4. #4 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Is there a guide on this site on how to do it for the 3.1l?
  5. #5 Re: Lower Intake Manifold Leak
    You are thinking the 3.8 smutty. The 3.1 is a little different and doesnt have the rubber end pieces like the 3.8.
  6. #6 Re: Lower Intake Manifold Leak
    Maybe. I would look on wbody.com or 60degreev6 there might be more info over there on the 3100 most of the info here is for the 3800.
    I just did one of these like a month ago and I cant remember where i put rtv.
    There are a few vids up on youtube.
    http://www.youtube.com/watch?v=rUlBJNK-80s
    http://www.youtube.com/watch?v=4IiMmMsqOzY
    or a guide with pics http://60degreev6.com/forum/showthre...e-gasket-howto
    -Edit- Looks like you were right smutty.
  7. #7 Re: Lower Intake Manifold Leak
    Rtv on each edge of the lim where there isn't a gasket. I just put new o rings on the coolant lines
  8. #8 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Ok I fixed the lower intake manifold. Now i'm trying to get it ready for an emissions test but all of the sensors are ready but one. Every sensor is ready except the C sensor, but i don't know what it is. Can any one tell me what the name of the sensor is so I can replace it.
  9. #9 Re: Lower Intake Manifold Leak
    C sensor? What code is it throwing?
  10. #10 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    The only code i still have is a p0171
  11. #11 Re: Lower Intake Manifold Leak
    You have a vacuum leak somewhere still.
  12. #12 Re: Lower Intake Manifold Leak
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    "C sensor" Coolant temp sensor? Right next to the thermostat on the lower intake manifold. I didn't watch the vids but I've changed these gaskets a lot in my car and its super important to torque the LIM bolts perfectly or it WILL leak causing the lean condition. Take your oil cap off and feel if there is any positive pressure or a strong vacuum. If there is a strong vacuum in the crank case then its defiantly leaking. No silicon should be on the intake or coolant runners. The silicone is important were the head and the valve cover meet but not as much as the bolts. Invest in a inch pound torque wrench. Too tight and the gasket will leak and probably crack the middle intake runners so be careful. (All of this from personal experience and help from the awesome people on this forum)
  13. #13 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Thank you but what is the amount of pounds per inch. Because there's eight bolt, four outer and four inner?
  14. #14 Re: Lower Intake Manifold Leak
    Feb 2013
    Missoula, MT
    I use 60degreev6.com it has a lot of good info specs and like torque patterns. So then just find your engine and click on specifications.
  15. #15 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Thanks for the info that really helped me out. But now the only code popping up is a p0507. How do i fix this code, because i already replaced the IAC valve.
  16. #16 Re: Lower Intake Manifold Leak
    Feb 2013
    Missoula, MT
    Air is getting passed the throttle body somehow. You might have to back-track your work and double checking everything. I don't mean to scare you but that code along with a loud squealing sound lead me to find out that i had cracked my lower intake manifold were it meets the cylinder head from over-tightening. But thats probably not whats happening to you. Check your PCV for normal operation?
  17. #17 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    I took out the pcv valve and shook it to make sure it wasn't stuck. But I'm going to check the throttle body seal.
  18. #18 Re: Lower Intake Manifold Leak
    Jun 2013
    Buffalo
    Ok so far for rite now I have no codes. The p0507 code hasn't shown up every since I put a o-ring on the pcv valve.
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  3. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  4. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
