Thread: Heater prob
Results 1 to 6 of 6
  1. #1 Heater prob
    Mar 2013
    ny
    It's the blower motor I believe. I got the car and the only way to turn on the heat was to put in the fuse and it only turns on full blast. Well this morning I come to turn it on and it sqeels loud. I would like to get this fixed so I don't hve to keep plugging in a fuse to turn heat or ac on
  2. #2 Re: Heater prob
    If it only works on full blast then I say the blower motor resisitor is bad, and if the blower motor itself is now making noise, go ahead and replace both.
  3. #3 Re: Heater prob
    Mar 2013
    ny
    Now replacing them is a pita right
  4. #4 Re: Heater prob
    from what ive heard its not to bad, its under the pass side dash. a lot of people have changed them, used blowers seem to be the way to go as they are not cheap new.
    if you have water leaks when it rains that could have caused the fan to croak on you.
    theres a how to, to fix the leak if you have a wet pass side floor. http://www.grandprixforums.net/water...-fix-6961.html
  5. #5 Re: Heater prob
    They arent too bad. I'm a skinny guy and didnt have much trouble down there.
  6. #6 Re: Heater prob
    Mar 2013
    ny
    Yeah the motor can't be to hard it's the resistor. What explains the fact I gota use a fuse though. I dnt mind it being on full I just hate puttin the fuse in to turn it on
  1. a/c prob
    By russ99 in forum Shops and Community Heroes
    Last Post: 05-28-2013, 01:23 AM
  2. ABS Prob
    By Claydough3753 in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2013, 05:47 PM
  3. could this be a PCS prob
    By wpbboy81 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 08:43 PM
  4. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  5. I R DUM EGR prob
    By Red97GPGT in forum General Tech Discussion
    Last Post: 03-23-2009, 07:31 PM
