Thread: Could someone help me with understanding these numbers?
Results 1 to 10 of 10
kamuletoe Could someone help me with... 03-15-2013, 09:44 PM
Slick2500 Re: Could someone help me... 03-15-2013, 09:53 PM
DanPrixGTP Re: Could someone help me... 03-15-2013, 10:23 PM
kamuletoe Re: Could someone help me... 03-15-2013, 10:37 PM
dsmuts Re: Could someone help me... 03-16-2013, 06:53 AM
DanPrixGTP Re: Could someone help me... 03-16-2013, 05:10 PM
Fivefingerdeathpunch Re: Could someone help me... 03-15-2013, 10:06 PM
rperry435 Re: Could someone help me... 03-15-2013, 11:16 PM
dsmuts Re: Could someone help me... 03-16-2013, 07:23 PM
DanPrixGTP Re: Could someone help me... 03-16-2013, 07:39 PM
  1. #1 Could someone help me with understanding these numbers?
    Mar 2013
    AZ
    I've read that the fuel trim in double digits it bad, as well as the knock retard I'm seeing. I've seen it hit 6.0 at WOT. This is a gtp with only a custom intake from the thread in this forum. How bad are these numbers I'm seeing? Should I be really concerned? What should I look into fixing to get these numbers better? Fuel filter/o2 sensor?
    I'm a noob with cars sorry :/
  2. #2 Re: Could someone help me with understanding these numbers?
    If your car is stock 6* of KR could be likely. When you took that screen shot was that at idle? Your fuel trims don't look to bad if it hits 16.4 and stays there that is bad. Remove the MAF reading and check timing advance instead.
  3. #3 Re: Could someone help me with understanding these numbers?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Quote Originally Posted by slick2500 View Post
    Mine hits 16.4 and actually stays there.
    Just curious, but what is the cause of this, why is it bad?
  4. #4 Re: Could someone help me with understanding these numbers?
    Mar 2013
    AZ
    Slick Thanks for the input! I was honestly worried about my car after seeing these numbers lol! I have changed the MAF reading to the Timing Advance reading. What should I be checking for with these numbers?
    That boost reading is wrong, you have to read the MAP in/hgs to see what your vacuum and boost are at.
    5FDP Thanks for letting me know! I knew it didn't seem correct, but what the heck do I know!? Just to be sure I'm having it read correctly I went into Settings>Units>Don't display psi as in/Hg has NO check mark in it.
    Dan I hope you get yours figured out! Your sig pic looks like you have a nice setup!
    You guys are great thanks!
  5. #5 Re: Could someone help me with understanding these numbers?
    Depending on whether it's + or - 16.4 you are either maxing out the fuel you can throw in your car or pulling a bunch. Yours could be from your dieing fuel pump Dan.
  6. #6 Re: Could someone help me with understanding these numbers?
    Jun 2011
    Thats what I assumed it was from.
    Thanks Dan... The Man.
  7. #7 Re: Could someone help me with understanding these numbers?
  8. #8 Re: Could someone help me with understanding these numbers?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I assume that's the torque app I didn't know it had Kr. Never found it on the list of display options. Oh well I've got an aero force on the way
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  9. #9 Re: Could someone help me with understanding these numbers?
    You can just call me the best Dan lol
  10. #10 Re: Could someone help me with understanding these numbers?
    Jun 2011
    Best Dan...
    Next to me, that is.
  1. Help understanding?
    By Quarterpastgone in forum PCM Tuning
    Last Post: 07-11-2012, 09:38 PM
  2. understanding dexron
    By MyPrixGT06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-21-2011, 11:56 AM
  3. Understanding electronics in our cars
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 12-16-2010, 10:10 AM
  4. PCM upgrading understanding
    By Lukus in forum PCM Tuning
    Last Post: 09-24-2010, 02:33 PM
  5. Am I understanding spark plugs right?
    By JDCMoney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 02:01 PM
