Thread: Grill
Results 1 to 6 of 6
  1. #1 Grill
    GT Level Member GrandPriest24's Avatar
    Jan 2013
    Michigan
    How to pop out the front grill on 02 Grand Prix
  2. #2 Re: Grill
    They screw in...
    also, did you get my PM I assume?
  3. #3 Re: Grill
    2 Phillip head screws on each one
  4. #4 Re: Grill
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    It's very straight forward.
    If you just look at the grill, you should be able to see how they come out.
    Use your brain... bruh.
  5. #5 Re: Grill
    Apr 2012
    Goderich, Ontario
    Should of said you gotta take the hole front bumper off to get the grills out.
    -Paul Walker
  6. #6 Re: Grill
    Sep 2011
    Copperas Cove, TEXAS
    #2 Philips Screw Driver
    Remove two screws in the lower part of the grill, grab and remove.
    Repeat process on the other side.
    Continue to learn everyday.
  1. Is the "Figure Grill" the only drop in replacement grill for the GXP?
    By Walleyealx in forum Visual/Body Modifications
    Last Post: 12-18-2011, 02:06 PM
  2. Anyone ever put a grill here?
    By Xorbex in forum Visual/Body Modifications
    Last Post: 05-18-2011, 12:36 AM
  3. new look for the grill
    By f3racer in forum Visual/Body Modifications
    Last Post: 03-04-2011, 08:28 PM
  4. Has anyone used this grill?
    By abuckley1290 in forum Visual/Body Modifications
    Last Post: 01-11-2009, 07:10 PM
