Hey bro, im not overly experienced with super chargers, but i do know a fair bit: does your exhaust sound different than usually? you might have a clogged cat causing there to be too much exhaust being forced back into the engine. i would HIGHLY recommend stop flooring it, drive it very cautiously with rpms, you do not want to much presssure in the engine it could cause: engine blowing (worst case), seals broken, head gasket blowing, cam misfunction, valve seal forced the wrong way, and youre probably sucking way to much fuel.
