Thread: Misfire under Boost please help!
Results 1 to 16 of 16
  1. #1 Re: Misfire under Boost please help!
    14-15 PSI means is modded or very broken.
    Mod list?
    What brand/product line ignition products did you use?
    EVAP leak and vacuum leaks are two different things.
    If you have a vacuum leak that will cause fueling issues (see misfires) and/or lost boost depending on location of vacuum line.
  2. #2 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    I have a upgraded ECU, pulley, headers, CAI, full exhaust system with no CAT, but i have a chip for the no CAT and cooling system for headers. It says vaccum leak, to be specific. Yeah it sucks! it's a round about right now
  1. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  2. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  3. Misfire when car warms up and no boost
    By jjuver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 06:26 AM
  4. Misfire when getting boost on 99 gtp help!!
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 11-21-2010, 10:20 PM
  5. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
