Thread: Misfire under Boost please help!
Results 1 to 16 of 16
  1. #1 Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    Hello everyone,
    I have a real head scratcher here. I have a misfire only under when I demand boost. I have replaced plugs wires and coils but it still misfires like a bastard, I have lost alot of fuel mileage and lost some boost as well. Usually pumps about 14-15 psi of boost but has dropped to about 11psi. If I floor it it will misfire and then go and my Check engine light will blink then go off. I do have a code right now but its an evap code for a vaccum leak not sure if that's the cause or not. Not sure if it's low compression in a cylinder or a fuel delivery problem, If anyone has Ideas on where to start that would be great.
    Blaine
  2. #2 Re: Misfire under Boost please help!
    Donating Users Jordan's Avatar
    Oct 2011
    Richland Center, WI
    Sounds like the same problem I'm having. Was just about to change plugs and wires. I'm also curious to the problem here.
    2009 Cobalt SS/TC Coupe |
    Summit White | 131k | ZZP charge pipes, ZZP heat exchanger, ZZP 3" downpipe, HP tuned, Muffler delete, K&N Typhoon intake, dual interceptors, retrofits with switchback halos
    2006 Grand Prix GXP | Black | 95k
  3. #3 Re: Misfire under Boost please help!
    14-15 PSI means is modded or very broken.
    Mod list?
    What brand/product line ignition products did you use?
    EVAP leak and vacuum leaks are two different things.
    If you have a vacuum leak that will cause fueling issues (see misfires) and/or lost boost depending on location of vacuum line.
  4. #4 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    I have a upgraded ECU, pulley, headers, CAI, full exhaust system with no CAT, but i have a chip for the no CAT and cooling system for headers. It says vaccum leak, to be specific. Yeah it sucks! it's a round about right now
  5. #5 Re: Misfire under Boost please help!
    No cat rules that out.
    Most end up running around 10-11 psi with those modifications.
    Still need to know what ignition products you used. If they were used MSD coils, that would account for the high load misfires.
    Side note: there is no chip tuning available for your PCM AFAIK. Flash tuning is what's used. DHP or HPT being the main two pieces of software/hardware to do it.
  6. #6 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    Most of the modding was done before I got it so I'm going off what I know to be honest, the ignition products were OEM and delco plugs and wires
  7. #7 Re: Misfire under Boost please help!
    ICM can cause high load misfires.
    Fuel pressure could be falling and resulting in lean misfires. What did the old plugs look like?
  8. #8 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    honestly no idea i had a garage do them cause I wasn't doing them in the freezing cold! I just have read other people with threads and it could be so many things, my car was misfiring at cylinder 5 and 6 and the code went away but its still doing it at high rpms
  9. #9 Re: Misfire under Boost please help!
    Did you request the work or ask them to fix the misfire?
  10. #10 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    I asked them to fix the misfire and had them do plugs wires and coils cause I read that those are the most common reasons why it happens
  11. #11 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    They said the misfire code went away which it did but still misfires when I start to give it boost or went I just floor it
  12. #12 Re: Misfire under Boost please help!
    SE Level Member johannib's Avatar
    Jan 2013
    Traer, Iowa
    Does the SES light flash when it's misfiring? My car did the same thing, ran fine but as soon as it added boost it misfired. I bought a used OEM coil pack from a junk yard for CHEAP and went through and swapped it out. Everytime I swapped one out I'd take it out and drive it, if it didn't fix it I put original coil pack back in and moved to the next one. It ended up being the last coil pack I swapped out, no more misfire and lots of power!
    You may try using an HEI ignition tester to put load on your wires, coils and ICM. Here's what an ignition tester is, Part 1 -HEI Spark Tester: How it Works. Make sure it is an HEI one. Some autoparts stores carry them or order online at Amazon for around $10.
    Good luck
  13. #13 Re: Misfire under Boost please help!
    Feb 2013
    Saskatchewan
    Hey bro, im not overly experienced with super chargers, but i do know a fair bit: does your exhaust sound different than usually? you might have a clogged cat causing there to be too much exhaust being forced back into the engine. i would HIGHLY recommend stop flooring it, drive it very cautiously with rpms, you do not want to much presssure in the engine it could cause: engine blowing (worst case), seals broken, head gasket blowing, cam misfunction, valve seal forced the wrong way, and youre probably sucking way to much fuel.
  14. #14 Re: Misfire under Boost please help!
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by Aaronfrom View Post
    Post #4
  15. #15 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    Yes as pointed out above I don't have a CAT it's a straight 3' down pipe to the y pipe then flowmaster mufflers, so you can rule out the cat, The exhaust actually helps being so loud cause you can hear when its misfiring, Also when Im in park I will rev the RPMS up to about 4000 right before the supercharger starts to kick in and you can feel and hear the car vibrate and studder so I dont know if that gives any one else a clue of what it could be. I just replaced the ICM as well so the whole ignition system has been replaced now I'm just itching my head of what else....
  16. #16 Re: Misfire under Boost please help!
    Feb 2013
    Wimington, MA
    And yes to joann the SES light does flash when misfiring, also stays on and has a vaccum leak code.
  1. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  2. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  3. Misfire when car warms up and no boost
    By jjuver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 06:26 AM
  4. Misfire when getting boost on 99 gtp help!!
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 11-21-2010, 10:20 PM
  5. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
