Thread: Coolant leak NEED HELP!
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: Coolant leak NEED HELP!
    Yoga city
    i had this happen and was short of funds on the ol gtp, couple weeks after i bought her. Crack right down the middle of the side. Drained, dryed and actually opend the gap a bit and jb welded it shut. No leaks over a year later and to my knowledge the kid who bought is beating the piss out of it and no issue
    Aug 2011
    Kenosha
    I would not put any stop leak or anything like that in there. A guy on another forum I'm I posted pics of a motor tear down that had stop leak in it, all the coolant passages in the blocked were clogged with that ****. If you wanna go the hack route try the jb weld. But your more than likely going to have to replace the radiator anyway so just save time and do it the right way first.
  3. #3 Re: Coolant leak NEED HELP!
    Yoga city
    im just gonna say, sometimes, sometimes, we have to improvise lol i would never do that now adays, but when in a bind it has to happen.
  4. #4 Re: Coolant leak NEED HELP!
    I'd jb weld it if you don't have much cash I've done it on a couple of cars with no problems.
  5. #5 Re: Coolant leak NEED HELP!
    Josh..that's likely someone that poured a ton into their motor. One dose shouldn't clog passages.
    When/if you jb weld. I'd suggest considering the one made for underwater. It'll adhere better if there's any moisture on your rad. Definately scuff the surfaces well and overlap a bit. The endcaps being plastic based do expand and contract. Which is why it cracked.
  6. #6 Re: Coolant leak NEED HELP!
    Dec 2012
    Philadelphia Pennyslvania
    im just going to replace it going to the scrap yard to pull one
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. Please help.. Coolant leak
    By pelon69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2011, 04:30 PM
  3. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  4. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
  5. Coolant Leak
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:16 AM
