Thread: Coolant leak NEED HELP!
Results 1 to 20 of 26
  1. #1 Coolant leak NEED HELP!
    Dec 2012
    Philadelphia Pennyslvania
    My car has had a slow coolant leak for a while and I have to refill it about 1 time a week which doesn't bother me but today after school I started the p.o.s and it sounded like the engine was gargling water when I got home from school (less then a 2 mile drive) I went to open the hood but before I did I saw a 6 inch wide puddle of coolant and the car had been parked for about a minute I have an idea of where the leak is coming from and have pictures but dont know how to post them and have no clue how to fix the leak I need some help guys
  2. #2 Re: Coolant leak NEED HELP!
    Ohio
    photobucket...
    im guessing its your coolant elbows
  3. #3 Re: Coolant leak NEED HELP!
    Dec 2012
    Where are they located
  4. #4 Re: Coolant leak NEED HELP!
    Ohio
    belt side.
  5. #5 Re: Coolant leak NEED HELP!
    Dec 2012
    It's coming from the other side Im working on the photo bucket thing hold on
  6. #6 Re: Coolant leak NEED HELP!
    Ohio
    what car????????????????????????????????????
  7. #7 Re: Coolant leak NEED HELP!
    Dec 2012
  8. #8 Re: Coolant leak NEED HELP!
    Dec 2012
    98 gt I put the pictures on photo bucket
  9. #9 Re: Coolant leak NEED HELP!
    Ohio
    appears you have a crack in your radiator
  10. #10 Re: Coolant leak NEED HELP!
    Dec 2012
    Daaamn so a new radiator or if its not bad do you think I can get that liquid metal radiator stuff
  11. #11 Re: Coolant leak NEED HELP!
    Ohio
    It most likely won't work.
    Just get a new radiator
  12. #12 Re: Coolant leak NEED HELP!
    Dec 2012
    Im gonna try it anyway ten bucks a bottle why not Do you have any suggestions on brands of radiators or anything
  13. #13 Re: Coolant leak NEED HELP!
    Ohio
    Are you talking about something to pour in the radiator??
  14. #14 Re: Coolant leak NEED HELP!
    Ohio
    just go to advance and get one. or order from rock auto. it will be alot cheaper
  15. #15 Re: Coolant leak NEED HELP!
    if the tank cracked on the side of the rad, nothing will fix that leak. or slow it down.
    dry it up all nice, run it and watch for the leak source. pin point where its coming from.
  16. #16 Re: Coolant leak NEED HELP!
    Dec 2012
    I have searched many times and thats the most accurate spot possible that I've seen for a leak. And yes something that you pour into the radiator
  17. #17 Re: Coolant leak NEED HELP!
    Ohio
    i wouldn't... That definitely will not stop an external leak.
    quit beating around the bush and fix it properly before you **** something else up pouring **** in there
  18. #18 Re: Coolant leak NEED HELP!
    Dec 2012
    im broke but its the proper way to do it your right But do you know what the gargling sound it was making was?
  19. #19 Re: Coolant leak NEED HELP!
    dude your in PA go hit a junk yard up, they are cheap warrantied and you learn how to take it out on a car thats not yours. win win all day long.
  20. #20 Re: Coolant leak NEED HELP!
    You aren't far from wegotused.com aka Harry's yards. Look at the specials..you can likely get a radiator for under $30
    Bring an
    10mm socket
    13mm socket
    15mm socket
    Ratchet
    15mm open end wrench
    16mm open end wrench
    17mm open end wrench
    18mm Open end wrench
    Nice sharp razor knife
    Pair of wire cutters
    Small pick
    Remove the support bars from the struts to front
    Cut the wires going to the level sensor on the passenger side
    Remove the fans with 10mm, throw them on ground
    Remove the trans line fittings. Either using the pick or a wrench depending on it's type.
    Cut radiator hoses
    Remove radiator hold downs 10mm
    Remove the two motor mounts from the front of the car and at the engine (13mm and 15mm)
    Rip wiring harness off front support to make room to pull radiator
    Lift radiator out and smile.
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. Please help.. Coolant leak
    By pelon69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2011, 04:30 PM
  3. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  4. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
  5. Coolant Leak
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:16 AM
