You aren't far from wegotused.com aka Harry's yards. Look at the specials..you can likely get a radiator for under $30
Bring an
10mm socket
13mm socket
15mm socket
Ratchet
15mm open end wrench
16mm open end wrench
17mm open end wrench
18mm Open end wrench
Nice sharp razor knife
Pair of wire cutters
Small pick
Remove the support bars from the struts to front
Cut the wires going to the level sensor on the passenger side
Remove the fans with 10mm, throw them on ground
Remove the trans line fittings. Either using the pick or a wrench depending on it's type.
Cut radiator hoses
Remove radiator hold downs 10mm
Remove the two motor mounts from the front of the car and at the engine (13mm and 15mm)
Rip wiring harness off front support to make room to pull radiator
Lift radiator out and smile.
