Thread: Abs lights
Results 1 to 9 of 9
  1. #1 Abs lights
    Dec 2012
    Brimfield
    I just purchased an 04 Comp G with 74k miles. The abs /traction control lights come on alot. The dealer is trying to fix the problem. They have determined its an electrical problem. Have replaced both wheel bearings. Also brake position sensor has been replaced twice and calibrated. Has anyone else had this problem with the lights coming on all the time?
  2. #2 Re: Abs lights
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    i have a 97 grand prix with the same problem only when i hit bumps and if you figure it out please let me know
  3. #3 Re: Abs lights
    Quote Originally Posted by 97GPJJ View Post
    check the hubs for play, check the wires to the hubs, ( all 4 wheels) if you cant find anything get it scanned. that way you not wasting money tossing parts at it.
    big, you got a gremlin id guess. lets hope the dealer can find it.
  4. #4 Re: Abs lights
    Pennsylvania
    Quote Originally Posted by biggie1969 View Post
    If your dealer used a Tech II to scan it, they should be able to be more specific than "electrical problem." Problem could be abs module (faulty from factory, requires $150 rebuild), either of the other two wheel bearings, or any of the wiring in between.
    I'd say you can rule out the abs module if hitting bumps is the culprit. Wire short or bad sensor is my guess, but a Tech II should give you a better idea.
  5. #5 Re: Abs lights
    Oct 2012
    oakdale mn
    this is going to sound really stupid and some might not agree with this but what i did was unplug your wheel bearing grab a can of coke soak the connections in coke for aprox 5 minutes rinse off the stickiness and plug back in i never had a problem again
  6. #6 Re: Abs lights
    Pennsylvania
    ...one might argue that a can of electronics cleaner might not attract bees.
  7. #7 Re: Abs lights
    Oct 2012
    oakdale mn
    lol yeah that works too usualy a bit of corrosion inside those connections
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I have repaired many abs problems over the years.
    The specific problem I see is the wiring from the abs module to the wheel bearing connector.
    Depending on the code for which front wheel (because I've never repaired a rear) and sometimes it's both but the twisted pair have a break somewhere along the line. The easiest repair is to twist up a set of wires and run a new set. Let me know of you need a pin out of the abs module. Usually take me an hour to do both.
    Just a heads up it may not set any codes and that only watching speed sense data with a tech2 or comparable scanner will help determine which one is the problem. Sometimes I dont even bother with replacing one cause I've seen both sides cause the problem. The wires MUST be twisted to prevent interference in the ac signal . :beer:
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  9. #9 Re: Abs lights
    dont for get the di-electrical grease while your at it. just a dab will do ya.
  1. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  2. Shifting Lights , AC Lights, Door Lights All Went Out?? Grand Prix 04
    By Levi Hardin in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2012, 12:49 AM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
