Quote Originally Posted by biggie1969 View Post
I just purchased an 04 Comp G with 74k miles. The abs /traction control lights come on alot. The dealer is trying to fix the problem. They have determined its an electrical problem. Have replaced both wheel bearings. Also brake position sensor has been replaced twice and calibrated. Has anyone else had this problem with the lights coming on all the time?
If your dealer used a Tech II to scan it, they should be able to be more specific than "electrical problem." Problem could be abs module (faulty from factory, requires $150 rebuild), either of the other two wheel bearings, or any of the wiring in between.
Quote Originally Posted by 97GPJJ View Post
i have a 97 grand prix with the same problem only when i hit bumps and if you figure it out please let me know
I'd say you can rule out the abs module if hitting bumps is the culprit. Wire short or bad sensor is my guess, but a Tech II should give you a better idea.
