Thread: Abs lights
Results 1 to 9 of 9
Threaded View
  1. #8
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I have repaired many abs problems over the years.
    The specific problem I see is the wiring from the abs module to the wheel bearing connector.
    Depending on the code for which front wheel (because I've never repaired a rear) and sometimes it's both but the twisted pair have a break somewhere along the line. The easiest repair is to twist up a set of wires and run a new set. Let me know of you need a pin out of the abs module. Usually take me an hour to do both.
    Just a heads up it may not set any codes and that only watching speed sense data with a tech2 or comparable scanner will help determine which one is the problem. Sometimes I dont even bother with replacing one cause I've seen both sides cause the problem. The wires MUST be twisted to prevent interference in the ac signal . :beer:
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  2. Shifting Lights , AC Lights, Door Lights All Went Out?? Grand Prix 04
    By Levi Hardin in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2012, 12:49 AM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
