Thread: How hard is it to change head gaskets??
Results 1 to 15 of 15
  1. #1 How hard is it to change head gaskets??
    Oct 2012
    Missouri
    Need help head gaskets blew how hard are they to change??
  2. #2 Re: How hard is it to change head gaskets??
    LIM gaskets?
    Head gaskets don't blow 99.9% of the time.
  3. #3 Re: How hard is it to change head gaskets??
    Oct 2012
    Missouri
    I replaced upper and lower intake gaskets and she still smokes white and i lose antifreeze but it dnt show up in my oil for some reason
  4. #4 Re: How hard is it to change head gaskets??
    Feb 2010
    TN
    i change head gaskets an a few RWD cars and it was not bad but I never did one on a FWD but from what I can see should nor be too much worse
    Quincy, Mass
    If its not in your oil then it's probably not the head gasket. How about your waterpump? Also check the coolant elbows make sure they aren't leaking. There's usually something else bad when the head gaskets go on these motors.
    How white of a smoke is it? Is it blueish? Is really thick white like you can't see behind you? A little white smoke is normal especially in these colder months. How long ago did you do the lim gaskets? Did you put rtv on the corners of the block when you did them?
    No more GP 04 Impala SS Indy:
  6. #6 Re: How hard is it to change head gaskets??
    Knowing your car and motor would help a lot. If its a 3100 don't bother
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    To answer ypur original question, it really depends on your mechanical ability and experience. Personally I think they are not bad at all. Just pay attention to detail. Clean head bolt holes.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  8. #8 Re: How hard is it to change head gaskets??
    Oct 2012
    Missouri
    Changes the water pump prob 150 miles ago wen i did the water pump i did the lim gasket and the gasket between the intake and sc to never looked at the elbow at all though. I did put rtv on it its jst a little white i mean its not like its come out of there crazy but i also put some seafoam in the tank so idk if my fuel filter is cloged again or if its burning off the last bit of seafoam
  9. #9 Re: How hard is it to change head gaskets??
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Quote Originally Posted by Sushamouf View Post
    Sent from my Droid
    I second this. Definitely depends on what you've done before and stuff. I don't think they are that bad either. But like Sushamouf said, clean the bolt holes and take your time with torque specs etc.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  10. #10 Re: How hard is it to change head gaskets??
    so im guessing you have a gtp but what year? DETAILS let us help you.
  11. #11 Re: How hard is it to change head gaskets??
    Donating Users
    Oct 2012
    lake city,fl
    head gaskets arent to bad just pay attention to detail make sure to clean all the mating surfaces really good with degreaser then a final wipedown with paint thinner and everything should be good!
  12. #12 Re: How hard is it to change head gaskets??
    Oct 2012
    Missouri
    I got a 1997 gtp
  13. #13 Re: How hard is it to change head gaskets??
    Head gaskets are just a bunch of bolts past the engine cover. Keep in mind that head and rocker bolts are TTY, therefore they should be replaced and not reused.
    Guys..read his other post ... he has two dead cylinders.
    I have seen a head gasket blow out between two cylinders and not effect coolant, oil or anything else. That was on a Ford though.
  14. #14 Re: How hard is it to change head gaskets??
    Feb 2009
    flintnasty MI
    I have seen heads fail that look like a blown headgasket.
  15. #15 Re: How hard is it to change head gaskets??
    That's cause you beat your motors...lol
  1. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  2. Replacing head gaskets
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 12:11 AM
  3. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  4. cylinder head gaskets
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2008, 09:33 AM
  5. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
