So you have an 01 GTP with a Gen V top swap. You likely have a throttle body adapter running the factory throttle body. If you are not running extensive mods the factory replacement will do you just fine. $800 for the part is BS and it only takes five minutes to swap them, you can do it your self with a trip to the part store. Post pics and additional info for further help.
