Thread: L36 Throttle on L67
Results 1 to 14 of 14
  1. #1 L36 Throttle on L67
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Would an L36 Throttle be able to work on a L67 and run right when doing an engine swap?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: L36 Throttle on L67
    Willoughby, Ohio
    the throttle body will fit yes, both the 3 bolt i believe. but not sure if they are the same size
  3. #3 Re: L36 Throttle on L67
    there will be a large step from throttle body to the blower. i would NOT recommend it. get an L67 throttle body, they are not expensive at all.
  4. #4 Re: L36 Throttle on L67
    Charles City, IA
    You can buy the l67 tb for like $30.
    SMGPFC Two Nipple General
  5. #5 Re: L36 Throttle on L67
    Kansas
    I got one if you need one
    SOLD 1999 GT Silvermist TS
  6. #6 Re: L36 Throttle on L67
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    yes it would work but why would you want to the l36 tb inlet is smaller just get a l67 tb and do it right u can get one cheap listen to bio
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  7. #7 Re: L36 Throttle on L67
    Portland Oregon
    Agreed that they're not really expensive, but I just want to throw in that I know a guy running an SSM90 top swap with a portet L36 TB running 12.5's. He was one of the pilot test cars for the SSM90 setup for Zoomer when they were considering making it. Dan Schmidt if you want to check his car out on ZZP's site under Customer's cars.
    So to answer the question, yes it is possible, and it shouldn't provide any real detriment to your setup if you need to run an L36 TB for some reason.
  8. #8 Re: L36 Throttle on L67
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Some of the people running an L36 TB with the SSM90 kit have problems on a cold start. Using an L67 TB seems to fix it.
    If you're trying to save tuning, don't bother. Too much other stuff needs changed.
    Quote Originally Posted by OH4CompG View Post
    And Ron Vogel ran 13.1s on ported exhaust manifolds and a 2.8" pulley. Just because it can be done doesn't mean that it should. If it's a ZZP ported TB, it's been bored out with a bigger throttle plate, too, so it's not really a fair comparison.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: L36 Throttle on L67
    Bowie, MD
    Thanks guys. Its juts that i recently had an engine swap from an l36 to a l67 2004 impala ss engine/tranny. Receive the car tuesday from the shop and they told me they used my old l36 throttle because they could not locate an l67 throttle in time. I seen a gtp at the junkyard last week with the complete engine still in tact. Would that gtp throttle work well with my impala? Thanks again.
  10. #10 Re: L36 Throttle on L67
    QCA, IA
    I assume you're using the L67 computer, did the shop tune it for the L36 TB? If not, the thing is going to run like crap, since the MAF calibration would be different. You can't just switch back and forth without changing the calibration.
    All 99+ L67 TBs were the same AFAIK, no matter what car they came out of.
  11. #11 Re: L36 Throttle on L67
    Portland Oregon
    For the record, I never said it SHOULD be done, I just said it is possible to run if you need to.
  12. #12 Re: L36 Throttle on L67
    Yes, all 97-98's had the bar in the middle of the TB and the '99-'03s were the ones to get...
    We all know you meant it
  13. #13 Re: L36 Throttle on L67
    Portland Oregon
    lol
  14. #14 Re: L36 Throttle on L67
    if you want a good ported throttle body you get the 97/98, port it, and put a 99+ MAF in it.
  1. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
  2. Throttle Bodies ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 11:03 AM
