Thread: Lookin for engine and tranny builders....
Results 1 to 20 of 28
  1. #1 Lookin for engine and tranny builders....
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I was hoping to get some feedback on Triple Edge transmissions. Good? Great? Not so? also looking for an engine builder. I have read TONS of good reviews about Billboost. Does he have his own website? Any and all suggestions are welcome. Thanks!!
  2. #2 Re: Lookin for engine and tranny builders....
    Cheaper to buy a short block than build a motor. It can handle the same power really.
    TEP is great, one of the best.
  3. #3 Re: Lookin for engine and tranny builders....
    TEP is great. That Bill guy is ok.... he only works from his home though...the PDM thing was a joke that kinda went semi real.
  4. #4 Re: Lookin for engine and tranny builders....
    Jul 2012
    Punch & Bill- Thanks for the info on TEP!
    Bill- would you be interested in building or rebuilding an engine for me? I am more than willing to compensate you for it...
  5. #5 Re: Lookin for engine and tranny builders....
    I don't build these bottom ends. I would hand a bottom end to a machine shop and build up from there. Honestly there's too much there that I wouldn't want to do in the bottom end. After that point, sure. I'd put one together for you. As for transmissions. I can assemble it, again though..the VB and channel plate would come from TEP. There's no better builder that I'm aware of for a transmission than TEP.
  6. #6 Re: Lookin for engine and tranny builders....
    Jul 2012
    My situation is this. I have a P0304 code. I checked the plugs,plug wires, and coil packs. I had a cylinder comprssion test done and the best it read was 75 lbs. and won't hold compression. My friend (who helped me do the test) said it's either a bad valve or a bad piston ring. I will start pulling off the top end tommorrow and praying it's just a valve. The engine has 138,000 miles on it, so in your opinion, would it be worth just doing a top end rebuild? This car is, or was, my daily driver. I'm hoping it will be again
  7. #7 Re: Lookin for engine and tranny builders....
    Me personally.. if it was mine. I'd pull the VC and see if it's a bad spring etc on top. Beyond that it's most likely piston/rings. Then I'd pick up another motor and drop it in. The money you'd spend to have stuff fixed is much greater typically than buying another.
  8. #8 Re: Lookin for engine and tranny builders....
    Jul 2012
    I understand. Thanks for the advice! If it is the just the top end, I'd like to make arrangements to tow my car up to you (I live in PA) and have it rebuilt. I have the passion and finances (sort of) to work on my car, but not the time or facilities (no garage). If it is the piston / rings, I'll go ahead and buy a short block. Question though, would it be better to install the short block and bring the car up to you for the top end or send you the block first and then haul the car up when it's ready to be installed? Sorry for all the questions!
  9. #9 Re: Lookin for engine and tranny builders....
    If you need motor assembly. That's always easier on an engine stand. So leave the shortblock out. Likely though..you won't find many shortblocks.
  10. #10 Re: Lookin for engine and tranny builders....
    Mar 2012
    NC
    Bill has such a good reputation! Not like there could possibly be anyone in PA who does this kind of thing, too...LOL
    Where you located in PA?
  11. #11 Re: Lookin for engine and tranny builders....
    Jul 2012
    If there is someone closer, I'm all for it. That's why I started this post, to see who is out there
  12. #12 Re: Lookin for engine and tranny builders....
    Jul 2012
    thanks Tony!
  13. #13 Re: Lookin for engine and tranny builders....
    There ya go. I hadn't really thought of the Quincy MA guy as a PA builder. I'd recommend Hitman as well.
  14. #14 Re: Lookin for engine and tranny builders....
    Jul 2012
    Harrisburg
  15. #15 Re: Lookin for engine and tranny builders....
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  16. #16 Re: Lookin for engine and tranny builders....
    Mar 2012
    NC
    You're about 3.5 hours south of where I am from and will soon be again. I even have the Billboost seal of approval! lmao
  17. #17 Re: Lookin for engine and tranny builders....
    You are an easy 5.5 hours from me. That's a hike. Heck..I think you are only 2-3 from 2003 SSEi. 3 or so from Hitman. There's plenty of other builders out there.
  18. #18 Re: Lookin for engine and tranny builders....
    Jul 2012
    Hitman, I'm up for it if you are!!
  19. #19 Re: Lookin for engine and tranny builders....
    Mar 2012
    NC
    I'm always down. When are you looking for all this to take place? What exactly do you need done? I'm unemployed at the moment and will be leaving Boston for good in a few weeks, so once I get back I'll have plenty of time.
  20. #20 Re: Lookin for engine and tranny builders....
    Jul 2012
    Well, worse case scenario I guess is the piston ring so I'll have the motor pulled and then check on the availability/price of another motor vs. taking this one to a machine shop to have rebuilt. I'll pull all the goodies ,that I just got done installing LOL, off of this engine. Either way, I'll have a motor minus the top end ready for you. I am going to shoot for the first week in Nov., to coincide with my vacation. Same question as to Bill, would you want the engine in the car to rebuild top end or out of it? Also, do you tune? if so, then I may upgrade the cam, rockers, and springs. I have an Overkill PCM that I just recieved but it isn't tuned for an aftermarket cam.
  1. 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possible?
    By winterstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2012, 11:50 AM
  2. 99' gtp engine/tranny into 01' gtp
    By c4gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-29-2011, 08:20 AM
  3. engine problem codes..were to start lookin for repairs
    By Dragonblaze in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 12:09 PM
  4. lookin for tranny & engine!
    By gonzo915gp in forum General Tech Discussion
    Last Post: 07-19-2009, 09:52 PM
  5. Lookin for opinions here.. Engine build
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2009, 08:11 AM
