Thread: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possible?
Results 1 to 20 of 22
  1. #1 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possible?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    I have a 2005 GP GT and the transmission is going. I want to put a GTP engine and transmission into it instead of another GT. I know that Ill have to use the GTP computer. Is there anything else I would have to do? what years will work? Im going to be buying this stuff from a junk/parts yard if that makes a difference...looking for one that has around 30,000 miles on it.
  2. #2 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Meh on the GTP trans, the gearing in your car is better.
    The transmissions are the same...minus the HD Diff.
    Just top swap it.
  3. #3 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    my transmission is going bad though thats what i need to swap out. my dad said just do the engine too so i wanna do the gtp engine. im guessing if i did a gt transmission with a gtp engine i would have to reprogram the computer system and i dont really want to go through that. so a gtp engine will work in a gt?...am i looking to get anything from 04-08 for years (will 07 and 08 work too)? what is the easiest thing to do in this situation that you recommend?
  4. #4 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Florida
    if your changing the engine and trans you will need to change the computer anyway. and for that computer (PCM) to work with your interior computer (BCM) the vins will need to match... this will require tuning anyway. so you might as well pic the engine and trans you want and have the pcm tuned to match. there are mail order vendors who will sell you a pcm or you can ask around and find someone local to tune your car.
    I also agree with going with the non GTP trans. when i did my swap from the original 3.4L DOHC engine to a 3800 series engine i did this. i chose the regular 4t65e and also go the L36 and got a topswap kit. the non HD trans gives a gear ratio that allows faster acceleration and using the higher compression L36 will give me more power for the same boost level once i install the topswap.
    from the sound of it all though... you are considering changing the engine for a more reliable one. in this case go with the L32 and call it a day. for mods it all depends on how fast you want it, but i would start with headers as now is the time if the engine will be out of the car. Now is also the time for a cam if your plans all for it in the future. but i just dont see getting a diff engine only to crack it all open to drop in a cam... might as well cam your existing engine and do a gen V topswap.
  5. #5 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    im not familiar with the top swap kit. im just looking to get a gtp engine from a parts yard and a tranny and slap it in there. if a top swap kit requires taking apart the engine i dont really have time for that cuz i need to minimize time spent doing this. will a gt tranny work with a gtp engine? if i did a mail order PCM would they send it to me tuned to my transmission specs and vin# or would i still have to go to someone to have that done?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by mwinters29 View Post
    Well if you get a junker engine and don't do gaskets you're only wasting your own time. Same work involved on a top swap.
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  7. #7 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    i just dont kno what a top swap entails. im getting the junker engine to save money cuz i dont have 4000 to spend on a new engine and tranny. and im doing this cuz my dad did the same to his 2000 grand prix gt except he just put the same engine in, not the gtp so i just wanna know if putting the gtp in with a gt tranny will work and how much a PCM is gunna cost me to get and get it tuned
  8. #8 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Blue is close: The transmissions are close to the same, not the same. The differences in the transmissions are the differential, diff housing and the drive/driven gear sprockets. In an HD diff the sprockets are 33/37 with a 3.29 diff. This makes a 2.93 overall ratio. In a non-HD the sprockets are 35/35 with a 3.29 diff to make an overall ratio of 3.29.
    Quote Originally Posted by acidcrashdburnd View Post
    I disagree on this one. If the LIM gaskets are plastic, then they should be replaced with the newer aluminum ones. However on most of the years you are looking into, the gaskets are likely the aluminum ones. In addition, there would be no need to take off the heads for any reason. The amount of work is very different from LIM gaskets to top swap, based on the heads not having to come off.
    My suggestion based on what you've said would be to get the engine, trans and passenger axle (it's different lengths based on the HD diff or GT diff, GT being a little longer) Drop it in, pick up a vendor pcm with the correct vin for your car and the GTP programming for the rest. Maybe have them do a basic tune on it for you while you are buying it anyhow.
  9. #9 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    is it necessary to get the passenger axle? if so how much am i looking at for one from a parts yard? and i see you are also from CT. im from bristol. do you kno of anywhere i can look for this stuff? i kno of some places. and also where would you get the pcm? could i just get it from the car i get the engine and trans from? ive been looking online and i only see the upgraded pcm that you arent supposed to use on your car that you drive on the roads, says for track use only haha
  10. #10 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Wow, didn't realize you were Bristol.. We should get together sometime.
    Chuck and Eddies in Southington, there's a place in Webster (I think it's called Webster as well) and a few other places around. Axle..I'd likely expect $20-30 at the most. anything more and you might as well buy a new one from Napa.
    The PCM, You could grab the one from the yard, then have the vin etc changed up to meet the needs of the car. Since you have emissions to worry about, the vin must match in the pcm to the vin of the car. I've been there..dealt with that.
  11. #11 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Donating Users
    MA
    If you're looking at top-swapping the top-end, I'm local and have plenty of parts I could sell to you (GenV, LIM, etc)... plus, you have Bill who can install (if you need someone to do the work)
    1998 Intrigue - Parted out
    2008 G8 GT - Heavily modded
    2016 WRX STi Limited - Bolt-ons
  12. #12 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    alright thanks guys! my dad and i can do the install, we did the engine and trans for his 2000 grand prix when he had it so we should be fine. its just the tuning that will be needed thats throwing us off a little bit cuz thats the one thing he doesnt know how to do haha. @intrigue98. im not sure if ill need any parts, im gunna see what i can get from a parts yard but if i need any ill let you know. thanks for the offer!
  13. #13 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    oh i just thought of this...i have heads up display in my car and i absolutely love it haha...will a different pcm have any affect on that cuz i dont kno if i could give that up haha
  14. #14 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    No, it'll be fine.
    I have added HUD to around 10 Regals. It's one of the best features out there.
  15. #15 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Florida
    Not to thread jack, but bill. Addin the HUD you do t need the special glass? I was under the impression the gtps had a special windshield for the HUD. If that is not the case do you think I could put one in my monte? Is it just like wiring in the speedo and any other sensors?
  16. #16 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Yeah Z34, they come with special glass. However I've seen one out of about 20 that were done where the image was a little fuzzy. The rest look just like a stock install. It's about 8 wires using the 97-03 HUD. PM me for more info or check out http://www.grandprixforums.net/how-i...gal-40882.html
  17. #17 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    No, it'll be fine.
    alright that's good to know. i couldn't give up HUD
  18. #18 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    I understand. I found out it could be installed in Regals and it happened. Otherwise..I dunno if I'd have a Regal.
  19. #19 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Kemmerer, Wyoming
    good luck with the install. if you do have a little extra time while the engine is out you can do a top swap. which means taking a normally naturally aspirated 3800 and putting the supercharger on it. by doing it this way you will get more horsepower out of your engine.
  20. #20 Re: 2005 GT tranny is going, i want to put a GTP engine and tranny into my car. possi
    Jun 2012
    Connecticut
    so if i did do a top swap without putting the entire gtp engine in, how much money do you think i would be looking at if i got all the parts i needed from a parts yard?
  1. 99' gtp engine/tranny into 01' gtp
    By c4gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-29-2011, 08:20 AM
  2. How to remove engine from tranny ?
    By shauner01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 09:09 AM
  3. New Engine Same Tranny
    By Biglilkrb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 05:52 PM
