Thread: 98 GP Won't Start
Results 1 to 10 of 10
  1. #1 98 GP Won't Start
    Apr 2012
    Taylor, Tx
    '98 Grand Prix 3.8 not s/c.. . bought new relay and fuel pump, but still wont start. checked for spark and it's there. new plugs and wires. fuel pump won't kick on without jumping relay. fuel gauge reads full even though it has less that 1/4 tank. it will turn over but won't start.
  2. #2 Re: Why won't she start?!?!?!?!?!?!?!?!
    Fuel pump relay is controlled via the pcm.
    Has an alarm or anyting been added to the car?
  3. #3 Re: Why won't she start?!?!?!?!?!?!?!?!
    Apr 2012
    Taylor, Tx
    no alarm on the car hasn't worke as long as i have had it going on 4 years.
  4. #4 Re: Why won't she start?!?!?!?!?!?!?!?!
    You've had the car 4 years and it never started?
  5. #5 Re: Why won't she start?!?!?!?!?!?!?!?!
    Apr 2012
    Taylor, Tx
    no i've had it for 4 years and the alarm has never worked. . . car hasn't been running for about 2 weeks
  6. #6 Re: 98 GP Won't Start
    scanned for codes yet?
    SMGPFC Member #10
  7. #7 Re: 98 GP Won't Start
    What happened when it stopped working?
  8. #8 Re: 98 GP Won't Start
    Apr 2012
    Taylor, Tx
    drove home from work no problem. . . car wouldn't turn over cuz of no power... put it on charger and hasn't started since
  9. #9 Re: 98 GP Won't Start
    Apr 2012
    Taylor, Tx
    no check engine light isn't on
  10. #10 Re: 98 GP Won't Start
    Apr 2009
    Fort Worth TX
    There should be signal coming from the PCM (clear connector pin#3). It's a dark green wire with a white stripe. This is the wire that goes to the fuse box and activates the fuel pump relay. Check for a signal on that wire when the key is in the "ON" position. The signal only lasts for about 3 seconds so you'll have to have someone turn the key to "ON" while you check with a DVM or a 12 volt light tester.
    If there is no signal it can only be one of four things:
    1) Ignition switch
    2) Security System
    3) PCM
    4) Dead short in the signal wire itself
    I'm guessing the security system since you say it has never worked.
  1. Sad Start To A New GP Guy
    By Dragan in forum Introductions/Noob Questions
    Last Post: 05-02-2011, 11:17 AM
  2. Car won't start!!!
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 05:49 PM
  3. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  4. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
  5. Start Me Up!!!
    By coolken84 in forum General Tech Discussion
    Last Post: 02-14-2009, 01:47 PM
