Thread: 98 GP Won't Start
Results 1 to 10 of 10
Threaded View
  1. #10 Re: 98 GP Won't Start
    Apr 2009
    Fort Worth TX
    There should be signal coming from the PCM (clear connector pin#3). It's a dark green wire with a white stripe. This is the wire that goes to the fuse box and activates the fuel pump relay. Check for a signal on that wire when the key is in the "ON" position. The signal only lasts for about 3 seconds so you'll have to have someone turn the key to "ON" while you check with a DVM or a 12 volt light tester.
    If there is no signal it can only be one of four things:
    1) Ignition switch
    2) Security System
    3) PCM
    4) Dead short in the signal wire itself
    I'm guessing the security system since you say it has never worked.
  1. Sad Start To A New GP Guy
    By Dragan in forum Introductions/Noob Questions
    Last Post: 05-02-2011, 11:17 AM
  2. Car won't start!!!
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 05:49 PM
  3. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  4. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
  5. Start Me Up!!!
    By coolken84 in forum General Tech Discussion
    Last Post: 02-14-2009, 01:47 PM
