Thread: transmission harness plug smashed
Results 1 to 8 of 8
  1. #1 transmission harness plug smashed
    SE Level Member threlfall92's Avatar
    Apr 2011
    belmont nh
    so my tranny is acting up in my gt, got the t/c lock up solenoid stuck on so it shifts like **** and other things are going wrong with it so i found a gtp as a parts car. doing the l67 swap and i dropped everything out the bottom and doing so, i forgot to unplug the harness going into the trans and it bent a few pins when i lifted the car. so i have two questions,
    a. can i repace that plug or should i just fix the pins? i dont wanna take the tranny apart to find out i cant replace it
    b. it was a pain in the ass dropping the whole cradle so is it easier to pull everything out the top and do the trans and engine come out seperately?
    cant upload the pic cause its too big but its the last pic in my facebook album:
    2000 grand prix gt | Facebook
  2. #2 Re: transmission harness plug smashed
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I've never pulled a motor and trans together... I have always taken the motor out the top and the trans out the side/bottomish area. As for that harness I actually have one out a 98 gtp trans that I blew up. If you wanna go through the trouble of replacing it. Has most if not all the solenoids still plugged in... Make me an offer if you want it.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: transmission harness plug smashed
    Sit the trans on a table. If you pull the side cover the electrical harness is very easy to replace. Be gentle when pulling the cover off to save the side cover gasket.
    Very easy to do. When you pull the side cover, it's right there.
  4. #4 Re: transmission harness plug smashed
    GT Level Member Tea Time's Avatar
    New Brunswick
    Kudos bill... i don't have this guys problem but if i did, that pic would have totally saved my azz.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  5. #5 Re: transmission harness plug smashed
    Thanks, but that's not a money shot. The four bottom bolts are torx. You should put the bit in them and give each a good whack to break them free from the aluminum/steel fusing that happens. Then when you round one out, take your small chisel and make a mark straight down. Then use that mark as a grip to tap it around counter clockwise and break it free. There's almost always one.
    There's the money shot. It is helpful having a bracket for the engine stand.
  6. #6 Re: transmission harness plug smashed
    New Brunswick
    Now ur just being a showoff...lol
    '97 GTP - Project
  7. #7 Re: transmission harness plug smashed
    Apr 2011
    belmont nh
    so if i pull the side cover off the whole harness unscrews? i dont see any bolts in your pic. that plug also looks different than mine
  1. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  2. Mystery Plug and Harness Swap Q's
    By tylerbinski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2009, 07:30 PM
  3. Got Smashed
    By GTPRiley in forum Track Sessions and Kills
    Last Post: 01-21-2009, 12:44 PM
  4. so i smashed up the PRIX
    By QwikGT in forum Off Topic Discussion
    Last Post: 07-18-2008, 01:05 PM
