Sit the trans on a table. If you pull the side cover the electrical harness is very easy to replace. Be gentle when pulling the cover off to save the side cover gasket.
Very easy to do. When you pull the side cover, it's right there.
Kudos bill... i don't have this guys problem but if i did, that pic would have totally saved my azz.
Thanks, but that's not a money shot. The four bottom bolts are torx. You should put the bit in them and give each a good whack to break them free from the aluminum/steel fusing that happens. Then when you round one out, take your small chisel and make a mark straight down. Then use that mark as a grip to tap it around counter clockwise and break it free. There's almost always one.
There's the money shot. It is helpful having a bracket for the engine stand.
