Thread: Joined GP forums - had fuel problem fixed next day
Results 1 to 5 of 5
  1. #1 Re: Joined GP forums - had fuel problem fixed next day
    Apr 2011
    ohio
    Thanks Pepino (your input & pics) & ZR1VETTE09 ..
    Hey Pepino how did the final result pan out? .... did you notice temp. - performance - fuel efficiency improvements?
  2. #2 Re: Joined GP forums - had fuel problem fixed next day
    Brewcity, WI
    wow... I've only put 7K miles on since last may.
    But I didn't notice any problems before I did my gaskets, just had some time to kill and figured I should get it done. I did get a little better MPG, but I also replaced wires/plugs.... **** I never did my front O2 yet. I've been running a drilled t-stats since I owned it, but I do notice that my car cools off alot faster when the fans kick in since I changed from dex to green peak. But I'm guessing the 5 flushes & cleaner I did helped that.
    Self-denied SMGPFC member #1
    SEARCH works!
  1. Fuel problem
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 10:01 PM
  2. a/c mode problem fixed!!!
    By Randy GP in forum General Tech Discussion
    Last Post: 10-16-2010, 01:57 PM
  3. Fixed Idle problem Now the rpm drops and brakes pull help
    By PTGsDaytona500GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2010, 07:14 AM
  4. My stalling problem not fixed!
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:22 PM
  5. **FIXED!** Fixing One Problem Created Another...
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-09-2010, 08:31 PM
