Thread: misfire with low acceleration *HELP*
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: misfire with low acceleration *HELP*
    I live here. TLSheff's Avatar
    Nice, glad to help
  2. #2 Re: misfire with low acceleration *HELP*
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    ^ditto.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: misfire with low acceleration *HELP*
    Newnan, GA
    I unplugged my MAF for cleaning and fired up the prix to see if it ran better. it idled far better in the driveway, but when i drove it it died on me twice in the 1.5 mile stretch i drove it. it died at every stop sign. I was forced to keep on the gas to keep it from dying to get it back home. SO i guess what i am really asking is what does it mean if the car runs way worse with the MAF removed?
  4. #4 Re: misfire with low acceleration *HELP*
    Quote Originally Posted by EJOUIE View Post
    That's normal. without the MAF the computer is running the basic air-fuel ratio for idling, so when you throttle it you won't get the right mixture because there's no sensor to tell the computer what to change.
    The reason for the test is that if you unplug the MAF and start the car and there is no change or it runs better, its the MAF sensor... if it runs worse, its something else.
  5. #5 Re: misfire with low acceleration *HELP*
    Newnan, GA
    so the MAF disconnect test only applies to the idle? It idled so much smoother without the MAF until i drove it.
  6. #6 Re: misfire with low acceleration *HELP*
    I'd let the others chime in with any intel, but my guess would be the sensor is bad.
    GM# 19179716 (AC Delco# 213-4338) Dealership List $360.08
    consult junk yard or auto parts store if you decide to replace it
  7. #7 Re: misfire with low acceleration *HELP*
    GT Level Member rmcardle3's Avatar
    Houston, TX
    ^^ On the MAF Sensor (because no OTHER codes...., right?).
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  8. #8 Re: misfire with low acceleration *HELP*
    Newnan, GA
    Quote Originally Posted by rmcardle3 View Post
    Only codes i keep getting are the elusive PO300 (random misfire), and the daily POS4U.
  1. Very bad vibration only when on acceleration
    By AKGTP in forum General Tech Discussion
    Last Post: 12-16-2012, 07:32 PM
  2. Odd Noise During Acceleration, Help.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-27-2010, 10:15 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. 00 gt pulls to right with acceleration
    By racerx217 in forum General Tech Discussion
    Last Post: 03-24-2009, 11:34 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
