Thread: Very bad vibration only when on acceleration
Results 1 to 14 of 14
AKGTP Very bad vibration only when... 03-28-2010, 03:08 PM
Viperkill97 Re: Very bad vibration only... 03-28-2010, 03:55 PM
02bluegp Re: Very bad vibration only... 03-28-2010, 08:46 PM
nawarkk Re: Very bad vibration only... 03-28-2010, 10:20 PM
Bio248 Re: Very bad vibration only... 03-29-2010, 07:47 AM
imdaman3 Re: Very bad vibration only... 03-29-2010, 08:32 AM
AKGTP Re: Very bad vibration only... 03-29-2010, 07:01 PM
AKGTP Re: Very bad vibration only... 03-31-2010, 12:15 PM
TorqueAutoMotiv Re: Very bad vibration only... 03-31-2010, 12:52 PM
Bio248 Re: Very bad vibration only... 03-31-2010, 01:52 PM
AKGTP Re: Very bad vibration only... 04-01-2010, 07:27 PM
Bio248 Re: Very bad vibration only... 04-01-2010, 07:33 PM
Firehawk031 Re: Very bad vibration only... 12-15-2012, 06:55 AM
Burbman Re: Very bad vibration only... 12-16-2012, 07:32 PM
  1. #1 Very bad vibration only when on acceleration
    SE Level Member AKGTP's Avatar
    Hello to all;
    I have 2000 GTP, slightly modified, throttle body spacer, cold air intake, 3 inch down pipe no cat, with single O2 sensor, after market mufflers, ECU and a smaller pulley. The problem I am having is that I get a horrible vibration throughout the whole car only on acceleration. If I'm on the highway at 70 mph and I let up off the gas, its smooth riding. As soon as I give it just a little bit of gas to maintain that 70 mph, the vibration is back. The vibration is not in the steering wheel, just throughout the whole car. I checked and the wheel bearings are good, and there are new tires on the rear, all balanced. I'm not really sure where to go from here. Any help would be much appreciated.
    Frustrated,
    AK GTP
  2. #2 Re: Very bad vibration only when on acceleration
    Donating Users Viperkill97's Avatar
    Arizona
    Mine was doing that really bad, I went through an axle. My passenger side axle was in pieces. So you may want to check into that.
    Life goes by so fast, so why drive slow.
  3. #3 Re: Very bad vibration only when on acceleration
    Idaho
    Mine was also doing the same, it ended up being that both of my axles where bad.
  4. #4 Re: Very bad vibration only when on acceleration
    West Side Michigan
    CV Axle. I had the same problem.
  5. #5 Re: Very bad vibration only when on acceleration
    damn, all these correct answers. i was about to come in here and offer you $5 through paypal to search the subject and figure it out on your own.
  6. #6 Re: Very bad vibration only when on acceleration
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    axles, vibrates under a load only
  7. #7 Re: Very bad vibration only when on acceleration
    ALL OF YOU GUYS ROCK!!!! I love this site you have an question about a grand prix and you bound to get the answer here......AWESOME! off to the automotive store and I'm going to get both sides.
    Thanks
  8. #8 Re: Very bad vibration only when on acceleration
    zzp has a great deal on stage 1 90 bucks for both not bad at all.
  9. #9 Re: Very bad vibration only when on acceleration
    Apr 2009
    stockton ca
    have fun Pulling them the driver side i think it was was a b1tch ANd i was even using the slide hammer with the little cv bracket on it
  10. #10 Re: Very bad vibration only when on acceleration
    Quote Originally Posted by TorqueAutoMotiv View Post
    grow some bigger muscles. mine came right out with a nice pry bar.
  11. #11 Re: Very bad vibration only when on acceleration
    Oh boy here we go!!! can you just pop off the lower ball joint from the spindle and A-arm
    and then pull out the axle? I need to look under the car all the work I've done has only been under the hood.....lol
  12. #12 Re: Very bad vibration only when on acceleration
    yes, pop off the lower ball joint and then pull the axle out. youll still have to pop it out though, you wont be able to just pull it out.
  13. #13 Re: Very bad vibration only when on acceleration
    Dec 2012
    northeast
    Remember you MUST rotate tires by the manual or you can create this problem
  14. #14 Re: Very bad vibration only when on acceleration
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Quote Originally Posted by Firehawk031 View Post
    Huh?
  1. 01 GT: Surging during acceleration
    By possum25 in forum General Tech Discussion
    Last Post: 08-04-2009, 10:25 PM
  2. Bogging at 3k under acceleration
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2009, 10:35 AM
  3. Acceleration noise
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 06:55 PM
  4. 00 gt pulls to right with acceleration
    By racerx217 in forum General Tech Discussion
    Last Post: 03-24-2009, 11:34 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
