I have a 97 Grand Prix 3.8L non supercharged, I live in Phx Arizona so its always hot. It has been leaking from somewhere by the coolant tank on the drivers side so Ive just been watching it and adding what I can but, The other day I was driving to Class and I noticed my temp gauge was near 260F so i pulled off and got a ride from a friend. Later that night I went back to get it and added a gallon of water just to get it home and it was fine. Today I decided to do a Radiator flush, instead of draining it from the drain plugs I just removed the two main coolant hoses and let it drain. Then I just took my hose and flushed it out from the bottom outlet a couple times. I put it all back together and and added coolant. Its soppose to hold about 2.55 gallons but it was full after only 1 so I assume its just from the amount left in the engine. So I started it and let it run and it slowly got to 210F and stayed there, but what I am worried about is that like I stated before When it gets hot or to operating temp it has a solid steam of coolant leaking from the drivers side near the coolant tank, it leaks for a couple min and slowly stops. I dont know where exactly and I dont know if I just overfilled it but if I did then Why did it do that before? Anything you can tell me about it will help alot.
