Thread: Leaking Coolant
Results 1 to 7 of 7
  1. #1 Leaking Coolant
    Alabama
    Hello,
    I just bought a 2002 grandprix SE...i see that the coolant tank is losing coolant. I saw the green liquid on the bottom part of the engine? i am a little concered. Can anyone tell me what might be the problem?
  2. #2 Re: Leaking Coolant
    Wausau, WI
    leaking head gasket or Lower intake manifold?
    it could also be leaking hose, or water pump as well
  3. #3 Re: Leaking Coolant
    Alabama
    wow..i dont want the head gasket to be leaking. anything else will not be that expensive if i am right. What are other things i can check to make sure it might/not be head gasket.
    Thanks
  4. #4 Re: Leaking Coolant
    GTX Level Member cerick08GP's Avatar
    Trace the leak as far as you can, it will help us help you.
    Also, take deep breath. Since you actually see the coolant on the outside, it is most likely NOT a head gasket failure. So chill, it could be a $5 part that failed.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Leaking Coolant
    Wausau, WI
    keep us updated on what you found or if it is OK now...
  6. #6 Re: Leaking Coolant
    Alabama
    looks like there is no leak been checking !! am glad...thanks liquifire
  7. #7 Re: Leaking Coolant
    Wausau, WI
    your mechanic could have just spilled some that ran down the motor when he was changing your fluids as well. I hope it is nothing....keep an eye on it for a couple weeks
  1. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  2. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  3. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
  4. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
  5. tranny leaking.....
    By badgtp2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2008, 03:38 PM
