Thread: Traction control problem
Results 1 to 5 of 5
  1. #1 Traction control problem
    Oct 2017
    Idaho
    I have an 04 grand Prix and when i turn it on the traction control light comes on and says traction control off and when i press the tc button nothing happens could it be a faulty button or is there something else up P.S the ABS light isn't on
  2. #2 Re: Traction control problem
    Jun 2019
    new yrok
    same issue on mine, but abs light is on for me.
  3. #3 Re: Traction control problem
    Jun 2018
    Lehigh Valley
    Most likely a bad wheel hub or broken wire to the hub. Could also be the ABS module. The only real way to find out is to scan and get the codes.
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  4. #4 Re: Traction control problem
    Jul 2017
    macomb mi
    normally if its the button there wont be any lights on. you just wont be able to turn it off but if youd like to try buttons at the junkyard are cheap think I only paid like 2 or 3 bucks and simple to replace don't go to a parts store for one they cost more than some of the radios at Walmart haha
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  5. #5 Re: Traction control problem
    St. Louis
    Does your ABS light come on when you turn the key to ignition? It should come on with all the other lights and then go out once you start the car if there aren't any ABS issues.
  1. Traction control problem
    By Grand prix 06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2015, 02:13 AM
  2. Traction control problem
    By Grand prix 06 in forum General Tech Discussion
    Last Post: 10-13-2015, 08:33 PM
  3. steering/traction control problem
    By 2007GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2014, 03:11 PM
  4. traction control problem
    By Martin 04 in forum General Tech Discussion
    Last Post: 07-02-2014, 11:12 AM
  5. Problem with ABS and Traction Control
    By Widetrackjohnny in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2012, 11:31 AM
