So, my current car is the first one I had this long and that's been aging in my possession. I'm planning on keeping it forever (or whatever practical with cars that may mean) and did replace the transmission two years ago and little by little took very good care of it at lower and lower costs while little by little becoming an expert about everything about it.
It currently has close to 150K miles. It has an indicator of "oil age" or "oil life time" that decreases with time and is manually reset back to 100% at the time of oil changes. I've always been using this number in addition to miles and time to make the oil change decisions.
I usually change engine oil with the best high-mileage brands every time that age gets to around 55% which most of the time makes me change oil every month (too frequent, I guess!). In the last 10-20K miles, I started loosing some oil between changes (aging, tear and wear) that may get up to 1qt loss. I have the following questions:
1.If, theoretically, I change oil every 2 months, and add a qt every week (hypothetically), doesn't that make for more than a total oil change (disregarding the filter)?
2. If the answer to 1 is "yes" or "kinda", then can I start increasing the time/miles between oil changes? (probably from 55% to, say, 25% of oil age)
3. Is there an upper limit for the amount of lost/burned engine oil at which some kind of diagnosis/inspection/repair has to be done? and what usually, is the repair?
4. If the answer to 3 is no, and that engines can get to a point where there won't be any need for oil changes because oil is being ADDED continuously (only filters may be changed from time to time), then when is it a "good" time to rebuild/replace an engine?
5. I heard that replacing is better than rebuilding, and that remanufactured are the best option when it comes to the cost/quality compromise , and I tend to agree with both to some extent. How long (in KMiles) do those 3800 GM engines usually last (original and re-man'ed) for a well taken care of car?
thanks
(my car is a 2008 grand prix with all the luxury options that were available that year, and has close to 150K miles)
