Ok so lets get some basic ideas out in the world again. and some basic info on oil.
Conventional oil, non blend WAS oil that was cracked from crude oil THEN each manufacturers additive package.
About 10+ yrs ago the EPA started pushing for lower phosphorus and zinc levels (high pressure antiwear additives) so the manufacturers had to add come up with ways to beef up the high pressure capabilities.
THUS they came up with synthetic replacements.
Synthetic means the molecules are engineered in a lab rather that using raw element based like phosphorus and zinc. Synthetic oils are produced the same way, engineered rather than "cracked" from crude to base oils.
Thus when engineering the molecules they are all identical and the characteristics are designed in.
Synthetics have engineered to take the heat and stress and synthetic additive package for foaming, dispersants, detergents etc.
The bad thing is the replacements for zinc(zinc dithiophosphate or ZDDP) and phosphorus cant really be replaced as easy. Blended oils dont actually work as well thus making Brad Penn and Comp Cams high zinc oils useful for older car owners.
Roller cam engines have LESS issue but pitting and wear can still result.
Supposedly the EPA tried "these additives contaminate converters thus they need reduced/removed" then converter makers and OEMs got riled up on that, so they went to "its better for the environment sue to personal oil changes and improper disposal" which well over 90% of old oil IS recycled and very little is "dumped" anymore. I am sure every town had an old rock road just outside of town the county "oiled" so they dump their oil their too. Road oil is a lot different.
Anyway as the oil detergent/dispersant/anti-wear package was perfected, namely to deal with heat and wear and tear, gas reformulation to unleaded, etc the manufacturers and oil companies hit a "happy spot" and advertised 3 month/3000 miles and it worked as the average mileage WAS that.
Now everyone talks about better machine processes, better materials, yada, yada,yada.
Most of the wear on older cars came from carbon buildup, gasoline dilution from carburation, and some from parts getting better. But saying a straight machined cylinder in the 60s is straighter than the 2000s, sorry thats BS.
Now have they gotten better at using less material and DESIGNING stronger castings, sure but now we dont get decent engines that we can bore out a bunch to make bigger. Now we get engines that can only be over bored 10 or 20 thousandths.
When I started doing maintenance plans for businesses and car owners. I always look at severe service intervals rather than "normal" chart as no one is normal.
For granny who parks car and drives every other week to go to store and such, 3month/3000mi is bit overkill as they rarely HIT the 3000mil mark.
But at least every 6 month works.
But some of these car makers are claiming 7500-10000 mi intervals and some people just dont drive that much, but many drive a lot more. I was offered job with old employer but job is like 100mi one way. 5 days a week.
That would be 1000mi a week.
Oil lights work off time, heat,mileage,load algorithm.
Chose an oil/brand/weight that is accepted and stick with it.
Change oil and check in same spot at least weekly and not it with miles. Oil consumption will be two ways, continuously ie burning oil, generally shown with fouling plugs, smoking, etc.
OR from age/wear/tear/breakdown. and will usually happen all in a very short time. This is from oil reaching a limit of dilution/contamination/breakdown.
Many engines have this point and it should be a factor when deciding on oil change intervals.
BUT run an oil change, note when it gets low. I do know you can drive a qt low but you need to note oil level daily if you dont add that first qt. ALSO if you do add that 1st lost qt not how long it takes till it gets low again.
Proper inspection and evaluation depends on observed inspection. Oil level USED to stay high as fuel diluted it THEN when it got high enough the engine would stat consuming the diluted fuel, and as the level gets lower the oil temps go up and fuel boils off.
MOST oil consumption in current engines starts happening after 250-500 miles after new oil gets mixed with left over old oil, and additive package stabilizes in the sump contents.
Keeping proper records help deduce WHAT is going on. A steady diet of oil means mechanical or lubricant issues like worn parts or oil brand/type/weight not suited to your specific use.
You can use different weights, brands, etc.
Blended oil to synthetics, vice versa, or going to next heavy weight, truck oils, what ever.
Keep records and change one thing at a time. Had a customer who wanted Castrol in his car so he brought it. The car started using oil at about 60k, so I offered to change him up and see what happened, had him come by shop every week for oil checks. Switched him to Shell Rotella T, and first oil change at about 2000 miles the filter was HEAVY, the oil was filthy. 3rd oil change car stopped using as much oil.
Now for the other part, we did a tune up at same time, and I did compression test on couple cylinders. So when it quit using oil, the compression actually came up by 15 lbs.
Turns out the owners driving style didnt work using Castrol. So at the shop I worked at we had "Quaker State" which since I found out back then that Shell oil company owns/makes QS and Pennzoil and we started using shops 10w30 and he hasnt had issue since as he kept using same oil even when that shop shut down.
Oils like fuels, tires, even cars need finessing by trial ans error. First figure out if its using, leaking or normal consumption.
Devising a plan to WATCH, and record symptoms may take a bit but going from there is the way to properly decide if the engine is broken, damaged and running or ready to fail.
Crudding up the plugs is generally rings or valve stem seals. BUT on the newer cars, with higher combustion temps really make it hard to diagnose as they generally CAN and WILL burn the oil cleaners and we have thinner oil that will burn off easier. Converters will self clean to a point , hence the part about EPA claiming converter damage but generally in practice its crap argument, and if pluged you can use a product called cataclean from Mr Gasket to help clean off said contamination after repair or replacement.
Also if your tuning an older higher miles engine and keep fighting KR it can be caused by preignition/detonation from oil migration into combustion chamber. Couple of guys I met locally , father and son , have me helping beefup/build thier engines. One goes in sons car he got from grandma 04 GTP with chipped piston. Dad has an engine, supercharged and it has chipped pistons, but his plan is to install a Buick in his sandrail.
