FordMan77
Also, if you're not visibly loosing oil from a leak (check the front and rear manifolds for sings of oil dripping, which would be a valve cover gasket), then don't forget to change the PCV valve. Could be gunked up causing excess pressure in the crankcase.
When I replaced the engine in mine, I got a motor with around 140K on it for $300. Add in gaskets, coolant and small parts I was right around $500. It pays to shop around places like RockAuto, Ebay, Amazon, etc. I swapped the motor in my garage with no lift and basic hand tools (with some air ones thrown in for speed). Just removed the hood and pulled it out the top.
