Thread: Help installing a strut 00 Pontiac grand prix
Results 1 to 4 of 4
  1. #1 Help installing a strut 00 Pontiac grand prix
    Jan 2017
    Washington
    I had to replace the cv axle and when I'm trying to put everything back. The shock is to low to put the 2 bolts through it. I've tried everything I can think of. I've tried prying it up and that doesn't work. I've tried using a strut spring compressor and that only compressed the springs and not the strut.
    What do you guys think I should do?
    http://imgur.com/Y6Q9WoC
  2. #2 Re: Help installing a strut 00 Pontiac grand prix
    pull the lca and knuckle down till it lines up, then push together.
  3. #3 Re: Help installing a strut 00 Pontiac grand prix
    Oct 2014
    portland oregon
    Not totally sure but i think you want to put your axle through be for you hook the strut up. then push the knuckle down hook up strut and then axle nut
  4. #4 Re: Help installing a strut 00 Pontiac grand prix
    for sure, (good eye) slide the axle back in the hub first ,then push the lca down and install the strut.
  1. 2004 Pontiac grand prix strut bar?
    By GPOBD in forum 04+ Specifics
    Last Post: 03-11-2017, 10:16 PM
