Thread: Desperate need of help
Results 1 to 9 of 9
Nick Eldridge Desperate need of help 02-03-2017, 05:44 PM
Fivefingerdeathpunch Re: Desperate need of help 02-03-2017, 05:51 PM
BillBoost37 Re: Desperate need of help 02-03-2017, 05:51 PM
cheatah faheatah Re: Desperate need of help 02-03-2017, 05:52 PM
alenw62 Re: Desperate need of help 02-03-2017, 08:29 PM
alenw62 Re: Desperate need of help 02-03-2017, 08:31 PM
Nick Eldridge Re: Desperate need of help 02-03-2017, 08:46 PM
Slick2500 Re: Desperate need of help 02-03-2017, 10:10 PM
stealthee Re: Desperate need of help 02-04-2017, 11:31 AM
  1. #1 Desperate need of help
    Jan 2017
    Lamar,Arkansas
    How to remove 3100 motor from 2002 Pontiac Grand Prix SE
  2. #2 Re: Desperate need of help
    Remove hoses, lines, bolts, unbolt torque converter and motor mounts, then lift out of car.
    There is no step by step process for a 3100 on here that I know of. Watch youtube video's to see what you can find or just dig into it.
  3. #3 Re: Desperate need of help
    The short answer is unhook the fuel, electrical, unbolt and lift out. The long version is a lot longer and I don't have pics of it all. Do a search and likely you'll find a bunch of info on it.
  4. #4 Re: Desperate need of help
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    C4 explosive, Mythbusters style....Oh, wait, do you still need a car ? Forget it then..........
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: Desperate need of help
    Apr 2016
    Dalton, GA
    Remove the cooling fan assembly, battery terminal, serpentine belt, power steering pump. you will have to take the 2 motor mount bolts out of the passenger side mount to get the lower power steering bolt out, support the front of the motor with a jack. Remove Ac compressor, starter and set aside, disconnect the fuel lines. You will have to remove the upper intake to do this to give you the room to take the fuel lines off the fuel rail, There is a bolt you will have to take off on the side of the block(drivers side) below the black pipe that goes into the lower intake manifold after you remove the the air box. When you take the fuel fitting out of the fuel rail be careful of the aft screw fitting it has to be fairly level to get it to come out easy if it is hard to come out watch out as the o ring will fly off and that is a $20 O ring set. remove the transmission inspection plate and the torque converter bolts. Remove the rest of the electrical connections and vacuum lines. Remove trans to engine bolts and do not forget about the ***** bolt from the passenger side wheel well. I find it easier to remove the trans and engine as one unit along with the complete wiring harness. you must remove the CV axles, If you do this do not forget to disconnect both ABS sensor wires and the down stream OT sensor wires.
  6. #6 Re: Desperate need of help
    Apr 2016
    Dalton, GA
    If you need pics I have have an entire engine/ trans assembly sitting on the garage floor.
  7. #7 Re: Desperate need of help
    Jan 2017
    Lamar,Arkansas
    Pictures would be greatly appreciated
  8. #8 Re: Desperate need of help
    When I took my 3800 out of my car I just unhooked everything and anything I could see hooked up to the engine.
  9. #9 Re: Desperate need of help
    SWPA
    If you are asking this question the way you did, do you really have the ability to do this job?
  1. in desperate need of 2008 gxp wheels
    By johngillespie in forum Wanted To Buy - Parts
    Last Post: 10-02-2016, 07:07 PM
  2. Radio Help! Desperate!!!
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2011, 12:21 PM
  3. Need quick help im desperate!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 05-28-2010, 03:20 PM
  4. im in desperate need of help!
    By walterg in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2009, 09:52 PM
