Thread: Passenger side wheel wobble
Results 1 to 17 of 17
  1. #1 Passenger side wheel wobble
    Jan 2017
    Washington
    So a customer recently brought their 2000 Pontiac Grand Prix GT in for wheel wobble. I thought it was the brake rotor, but it still shook after I replaced it. I tried moving the cv axle and it was moving up and down slightly. Would I need to replace the cv axle or the wheel bearing?
  2. #2 Re: Passenger side wheel wobble
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    First, put offending wheel/tire on balance machine and check for bent wheel or tire out of round/tread separation. Before you throw more parts/money at it.... check ball joint, inner & outer tie rod ends, etc..
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Passenger side wheel wobble
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    When the car is in the air and you grab the wheel does it allow movement up and down, side to side, etc? How much movement?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Passenger side wheel wobble
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ryan? Are you posting on a forum to fix my car?
    But seriously, this is why I don't trust mechanics.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  5. #5 Re: Passenger side wheel wobble
    Jan 2017
    Washington
    Not sure who you are stocker but it's one of my close friends car.. plus I'm just starting to become a mechanic so that's why I posted on the forums so I'm guessing it's not yours. When I grab the wheel, it moves about 3-4 threads on the brake rotor
  6. #6 Re: Passenger side wheel wobble
    Jan 2017
    Washington
    Then the cv axle itself has slight movement, the guy said that he slid into a bridge due to the icy roads out. But the wheel isn't bent. That was one of the first things I did
  7. #7 Re: Passenger side wheel wobble
    Jan 2017
    Washington
    I haven't checked that, but I'm currently at work for another 6 hours. When I get home I'll check and let you know
  8. #8 Re: Passenger side wheel wobble
    Oct 2012
    Houston, TX
    When getting wheel movement, are your hands at 9 and 3, 10 and 2, or 12 and 6? This helps narrow down what could have play and be causing the problem. I do agree. In my time I have seem plenty of wheels that were bent or bad. Even more so I have seen tires that went out of round or had some tread separation that was hard to see until it was on the balancer.
  9. #9 Re: Passenger side wheel wobble
    GT Level Member mguzzo's Avatar
    Buffalo NY
    grab the tire at 3 and 9. if it shakes its the bearing / hub
    grab the tire at 12 and 6. if it moves its the tie rod
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: Passenger side wheel wobble
    St. Louis
    Isn't that backwards? I always check for bearing play at 12 and 6 (up/down movement) vs. the 3 and 9 (side to side).
  11. #11 Re: Passenger side wheel wobble
    Oct 2012
    Houston, TX
    Quote Originally Posted by FordMan77 View Post
    Yep
  12. #12 Re: Passenger side wheel wobble
    May 2016
    Rouge Island
    Maybe that's from a lying on the ground perspective ???? lol
  13. #13 Re: Passenger side wheel wobble
    Jan 2017
    Washington
    The wheel moves side to side, that would mean replacing the tie rod?
  14. #14 Re: Passenger side wheel wobble
    May 2016
    Rouge Island
    You would be replacing the tie rod END. Most likely the outer, but inners go bad too. Which end has play?
    Last edited by cheatah faheatah; 01-12-2017 at 06:11 PM. Reason: nix side, add end
  15. #15 Re: Passenger side wheel wobble
    Jan 2017
    Washington
    The part that connects the tie rod to the wheel bearing assembly is when it has play in it
  16. #16 Re: Passenger side wheel wobble
    May 2016
    Rouge Island
    IGU
  17. #17 Re: Passenger side wheel wobble
    take the nut off the tie rod, loosen the lock nut on the inner rod, then hit the flat spot of the knuckle where the tie rod passes through, 2, or 3 firm shots will pop it out. the car will need an alignment when your done, other side is likely shot too.
  1. Steering wheel wobble. HELP!!
    By 92builtbird in forum General Tech Discussion
    Last Post: 09-10-2014, 08:23 PM
  2. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
