Thread: The E85 Thread... Questions and Answers
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 94
  1. #41 Re: The E85 Thread... Questions and Answers
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 97AutoXVette View Post
    Note that E85 is pretty forgiving though. As in even this coming winter, when it is more like E70, than E85, I will not change my tune. I will just let it run on the rich side for several months (unless I have some issues, which I would report to this thread if so!)
    Changing tune for the winter is not necesary. Going from E85 to E70 requires about 6-7% less fuel, our PCM's can easily compensate for more than 15% in either direction. That is why you can run E30-50ish Without a tune on stock injectors if you wish.
    04 GTP -HAI, 1.9 rockers.
  2. #42 Re: The E85 Thread... Questions and Answers
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    would buying a "canned" tune for e85 be okay if on just a 3.4 set up? And then drop pulley sizes accordingly? Other than that all you'd have to get injectors right?
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #43 Re: The E85 Thread... Questions and Answers
    Aug 2013
    Sandy, UT
    Yes that would be fine, just make sure the canned tune is for the size of injectors you are getting.
  4. #44 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Quote Originally Posted by chris99gtp View Post
    Considering im running a stock tune on a sub 3.2 pulley you are probably fine lol.
  5. #45 Re: The E85 Thread... Questions and Answers
    Aug 2013
    Sandy, UT
    bump... just because.
  6. #46 Re: The E85 Thread... Questions and Answers
    But all the Facebook fags says that you need a tune no matter what mods you are doing. They said I was an idiot for telling some dude putting a cold air intake and a 3.6 pulley on his car that he didn't need a tune.......
    Sent from my Galaxy Far Far Away
  7. #47 Re: The E85 Thread... Questions and Answers
    Aug 2013
    Sandy, UT
    Oh i forgot that everything on the internet is true so they can't lie on facebook.... Lol.
  8. #48 Re: The E85 Thread... Questions and Answers
    Yeah I told them all they were ****ing retarded.
  9. #49 Re: The E85 Thread... Questions and Answers
    Jun 2012
    Illinois
    Great information to read, Also sent you a pm.
  10. #50 Re: The E85 Thread... Questions and Answers
    Kemmerer, Wyoming
    I'm running a 40% ethanol blend right now. I just switched over. after reading this, I realize I can richen the afr up some more. I was going for an 11.5 afr, but since I'm running 40% ethanol, can/should I go richer, and how much? also, the only thing I have changed in the tune is the maf table, because the E40 runs a lot leaner. one thing I noticed today when I was crunching the numbers to get the E40 is that since the gas pump has E70, if I mix equal parts of E70 with E10, it will make E40, so getting the right mixture is easy.
    I also have 42.5lb injectors
  11. #51 Re: The E85 Thread... Questions and Answers
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I just switched over to E85 last week. Had it dyno tuned by ZZP. Good power but I still need to do some cold temp starting fine tuning.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  12. #52 Re: The E85 Thread... Questions and Answers
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by brettstoner View Post
    What size pulley are you running now? Congrats on going E85. Welcome
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  13. #53 Re: The E85 Thread... Questions and Answers
    GTP Level Member
    Jun 2016
    Cleveland ohio
    What HP did you get with your setup?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  14. #54 Re: The E85 Thread... Questions and Answers
    Jan 2014
    United States
    *Updated 11/11/14*
    Timing Tables:
    1) MAKE SURE you zero out the AFR Correction Spark Table. Doing this prevents the car from adding 8* of additional timing at all times when running E85. I learned this the hard way through experimentation...
    I am seeing 8 degrees higher than the Base timing table. I don't see an AFR Correction Spark table. Where can I find this in DHP?
    Thanks,
    Nick
  15. #55 Re: The E85 Thread... Questions and Answers
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by nickolaughagus View Post
    I am not as familiar with DHP. Mind taking a quick snap-shot of all that you can change in the timing tables? (whichever drop down menus you have around timing). Should be able to help you from there, or someone else can also chime in.
    2002 GTP sedan:
  16. #56 Re: The E85 Thread... Questions and Answers
    Thanks,
    Nick
    what you mean 8 over? in the good fuel spark folder, the bottom rows are 10's. with dhp that 10 ends up being 15 in real life on a scanner. so what ever that value is figure its 5 higher really
    like mine are set to 7's thats 13.5 for me.
    and i dont recommend zeroing out that folder, so im not telling you where it is lol you can lean it out or add more fuel to it, but id not zero it.
  17. #57 Re: The E85 Thread... Questions and Answers
    Jan 2014
    United States
    I gotcha. Well based on my reading that tables not accessible in dhp anyway. So I guess I'll drop all my WOT timing by 8 in the good fuel table. It seems like a ghetto solution, but whatever
    Sent from my SM-G935T using Tapatalk
  18. #58 Re: The E85 Thread... Questions and Answers
    its in the pe folder, time vs rpm. on corn you'd likely want to make it richer some.
    on your scan whats your wot timing? or email me your bin so i can see what you set it to if your not sure what you did.
    with hpt the value you see in the file is the actual timing, but not in dhp. its way different.
  19. #59 Re: The E85 Thread... Questions and Answers
    Jan 2014
    United States
    For the record, I couldnt find the AFR Spark table in PowrTuners anywhere, but I just opened Tiny Tuners for a different reason and it's right there in the Base Timing section under Spark. If anyones ever wondering
  20. #60 Re: The E85 Thread... Questions and Answers
    GTP Level Member
    Jun 2016
    Cleveland ohio
    What is a good tuner to get??
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 08-12-2014, 05:43 AM
  2. Replies: 3
    Last Post: 07-15-2013, 12:53 AM
  3. not your typical "runs for 3 seconds and dies" thread.
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 09:35 AM
  4. Can't post a New Thread in the "For Sale - Vehicles"
    By sandite5 in forum Off Topic Discussion
    Last Post: 06-04-2010, 05:30 PM
