Quote Originally Posted by nickolaughagus View Post
I am seeing 8 degrees higher than the Base timing table. I don't see an AFR Correction Spark table. Where can I find this in DHP?
I am not as familiar with DHP. Mind taking a quick snap-shot of all that you can change in the timing tables? (whichever drop down menus you have around timing). Should be able to help you from there, or someone else can also chime in.
