Thread: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 112
  1. #61 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Mmmmm dem tips.
    04 GTP -HAI, 1.9 rockers.
  2. #62 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by johntremell View Post
    any idea how many finds per inch the frozen boost type 101 heat exchanger has?
    http://www.frozenboost.com/product_i...a933e9df1332fd
    I never measured one. Looks like 10-12 fins per inch.
  3. #63 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    I almost wish I had waited and installed a radiator like the VW one you are using. it looks pretty big so I wonder how difficult the install will be.
  4. #64 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member buickman104's Avatar
    NYC
    Any updates on the front mount heat exchanger install? Looking forward to seeing how it is mounted.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #65 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    I got a sensor for the sensor hole. Believe it is M22 x 1.5. Couldn't find a plug so ordered the sensor for $16.21 from amazon.
    Beck Arnley 201-1266 Thermo Fan Switch
    Sold by: Amazon.com LLC
    Been busy with my kids school activities. Don't think I will get it done this weekend.
  6. #66 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    you gonna mount a fan on the vw radiator? or just plugging the hole?
    the rad set up always seemed better to me. larger surface area to cool. and it wont hit the parking stops from being so low. and a fan can be mounted if thats even worth doing.
  7. #67 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Just looking to plug the hole in the radiator. Auto parts store could only find a m20 plug. Pretty sure the fans switch is none adjustable 200 deg f.
  8. #68 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    you think its worth mounting a fan at all? it can always be hard wired to a on off switch.
    when that other guy did the rad style install how to, the first thing i thought of was a fan on it.
  9. #69 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    I doing a 2 speed intercooler pump setup. Run the pump powet through a resistor so that flow is slow and water stays a long time in the FMHE. I have vacuum switch that closes when there is a lack of vacuum which will bypassing the resistor giving the pump full power (14 volts)
    I want the coolant flowing so that the line is cold right before the intercooler but I don't want my intercooler loop heating up.
    When you get into boost your radiator and supply hose are cold.
  10. #70 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
  11. #71 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    is it still going to have the same amount of ground clearance?
  12. #72 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Yes, same clearance. You won't be able to even tell it's there.
  13. #73 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
  14. #74 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    NYC
    I love how clean it installs. Thank you for the write up and great ideas.
  15. #75 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Awesome install
    04 Comp G.
  16. #76 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    finish tomorrow.
  17. #77 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Arizona
    I'd be worried with plastic endtanks on a metal bracket with no type of bushings or support from underneath.
  18. #78 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by 91parkave View Post
    This ones been on for 6-7 years.
  19. #79 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member
    Pittsburgh
    Looks Good, so when are we tuning this one?
    2003 SSEi,
  20. #80 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by 2003 SSEi View Post
    Not sure....... Busy with school activities, both kids are in B.E.S.T. Robotics and we have 3 weeks left till the competition. I'll be going after school everyday this
    Can you do a base tune on a PCM without the car? I have an extra 03 stock PCM. Might switch to 42# injectors and N*.
  1. VS Cam vs S2/Phenolic Intercooler
    By Nchristopherson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2013, 08:10 AM
  2. Ported gen5 and phenolic intercooler
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 05:51 PM
  3. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
  4. Phenolic Intercooler Spacer
    Last Post: 03-22-2009, 12:03 PM
