Thread: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 112
  1. #81 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    2 resistors 15 ohms each or 7.5 ohms as shown in parallel. About 5 volts to the pump with key on. Actual pressure switch (not vacuum) changes at about 1/4 psi. I can blow in tube and get it to change states.
    With vacuum pump runs slow with power through resistors.
    With boost pressure switch closes and bypasses resistors and pump gets 14 volts
    Theory is to keep the radiator and supply line cold as possible but have the fluid moving slowly.
    Looking at insulation CAI, need a black insulated pizza bag.
  2. #82 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member buickman104's Avatar
    NYC
    Would wrapping it in reflectix help?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #83 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by buickman104 View Post
    I think it would, just trying to find something that is good up to 160 degrees and looks good.
    Don't think this will take the heat.
  4. #84 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    NYC
    Well, I liked your intake idea and decided to build a w body version of your intake. Let me know what you think?
  5. #85 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Arizona
    Why not just wrap your manifolds and / or crossover
  6. #86 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by 91parkave View Post
    The inline CAI works great but it's aluminum and conduct heat really fast. Just looking for a little air insulation. Want to keep the temperature within 15 degrees of outside temperature.
    Wrapping exhaust manifolds isn't recommended, can cause cracks in the welds.
  7. #87 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Nice.
  8. #88 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Arizona
    Quote Originally Posted by sseilmnop View Post
    No cracks man, I've been wrapped for years no cracks. Others would say the same.
  9. #89 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    http://pages.ebay.com/link/?nav=item...d=151427940470
    CU98 radiator $49.99 on eBay. Looks like it has the sensor port plugged. Free shipping.
  10. #90 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Nov 2009
    PACNW
    Very nice job there. Need a nice SSEi for myself now after seeing that. My Grand Prix is too beat up to spend too much on, but if I change my mind, your kit is a deal at almost any price.
  11. #91 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Looking for smaller pulleys (2.8 and 2.9).
    Running a 3.0 now with no KR, I think I can take it to 2.8 with only front Plog and rear ported exhaust manifold. Rest of the exhaust is stock.
  12. #92 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Not even running a U-Bend Delete or DP?! If so, that's impressive...
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  13. #93 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    SSEi's don't have U-bend.
  14. #94 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mar 2014
    Cincinnati, OH
    Forgive me haha.. are the stock manifolds/crossover similar to the GTPs?
    2002 GTP sedan:
  15. #95 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 97AutoXVette View Post
    They are identical. From what I can tell. I cannot tell any difference between mine and GP ones.
    04 GTP -HAI, 1.9 rockers.
  16. #96 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Rear manifold and downpipe are different then GP. They are not interchangeable with the GP.
  17. #97 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Aug 2013
    Sandy, UT
    Really? Other than mine having a second manifold thing and a port for the airpump they look identical.
    Well i knew the downpipe was different
  18. #98 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    SE Level Member oldsman105's Avatar
    Queens, New York
    On stock injectors?
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  19. #99 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    I have 42# but not installed yet.
  20. #100 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member
    Pittsburgh
    or tuned
    2003 SSEi,
  1. VS Cam vs S2/Phenolic Intercooler
    By Nchristopherson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2013, 08:10 AM
  2. Ported gen5 and phenolic intercooler
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 05:51 PM
  3. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
  4. Phenolic Intercooler Spacer
    Last Post: 03-22-2009, 12:03 PM
