Trying to clean up the ssei tips. Is there good looking dual tips that work on a Bonneville? 2.0" inlet and I want them to stick out another 2.0" inches.
those tips look exactly like tips from a sunfire GT 2.4L with dual exhaust, im not sure if the year matters but my old one was a 99' and they were the exact same
Cold air intake
Spectre inline with 4" in and out.
Molded 3/4" heater hoses to the intercooler
2 pieces of 3-1/2 tubing
2 l67 stock rubber boots
Radiator is only 23" wide and Finns per inch is to small.
Need more research on brand (better fins per inch) of vw radiator and how to get one 25" wide. Here is one from zzp 5 or more years ago.![]()
I found good info on VW radiators.
I ordered an advance auto brand with low fins per inch count. I also orders without AC.
I have a Spectra Premium CU98 on order.
What are you planning to use as an overflow tank? Also going with a Bosch pump?
Great info. Amazon carries just about everything as long as you have a part number.
http://www.amazon.com/Spectra-Premiu...a+Premium+CU98
Your quick, that's were I got it coming from.
I'm going to use tee fitting and clear 3/4" hose. Yes to bosch pump.
Will the radiator come with the sensor hole plugged?
https://www.nationalpartsdepot.com/s...c-8854-60k.jpg
I've seen people use a short piece of heater hose and plug it with a chrome lug nut or whatevers handy.
