So if i have a 2001 GP GT with the non-digital DIC i can add in a Digital DIC? and i just need to make a few splices?
You mostly will splice wires...
The following wires can be spliced from the non-digital DIC:
Left Door
Right Door
Rear-Left Door (if 4dr)
Rear-Right Door (if 4dr)
Trunk
Washer Fluid
Dimmer
If not a few more (it's been a while)
You'll have to wire into the VSS line to pull the Speed Data for the millage/oil/etc.
Search on Google for: Digital DIC conversion Grand Prix
I believe AutomotiveForums has the diagrams still:
http://www.automotiveforums.com/t765...onversion.html
Last edited by StreetChariot; 04-08-2009 at 02:51 PM. Reason: Adding link with diagrams
Nice to see this is making its way around the net to help everyone out. Here are my original posts of this writeup which may have some additional information including working images:
Ontario Quebec Club Grand Prix • Login
ClubGP Message Forum troubleshooting
Thanks,
Pete
question...
Does anyone know why I'm getting flashing zeros?
I've been searching and searching but couldn't find any viable solution.
I suspect that the data is not being supplied (or not correctly supplied), but at where is it not getting enough information?
I checked tan wire from DLC-9 and dark green from back of speedometer, they all check and are connected from their sources to the soldering point of the pins.
Even tried connecting scanner to the OBDII port and no codes, it does connect.
It's 98 GP GT, and the digital dic I bought off the ebay is supposed to be from 1999 GP as well.
(Does HUD have to be present by any chance??)
Any, I mean ANY, ideas please!!
I just got my DIC in off of ebay, and It didn't come with any wires or any wires attached to it. Will i need those? or is there a connector already in the dash somewhere for it? Any help is much appreciated!
No, your car will probably come with the connector. If not, there are instructions above that tell you which wires to use.
BTW anyone that my able to help. I STILL have the problem I posted about above... About my new DIC knocking out my radio backlight. I haven't had time to work on it. Wondering if anyone has any suggestions?
