Thread: How to: '00-'03 Grand Prix standalone transmission fluid cooler
Results 1 to 20 of 62
Threaded View
BrandonHall10 How to: '00-'03 Grand Prix... 05-23-2015, 11:30 PM
chris99gtp Re: How to: '00-'03 Grand... 05-24-2015, 11:46 AM
keithr182 Re: How to: '00-'03 Grand... 05-27-2015, 04:55 PM
BrandonHall10 Re: How to: '00-'03 Grand... 05-27-2015, 05:45 PM
buford1972 Re: How to: '00-'03 Grand... 05-31-2015, 02:58 AM
BrandonHall10 Re: How to: '00-'03 Grand... 06-01-2015, 12:45 AM
BrandonHall10 Re: How to: '00-'03 Grand... 06-20-2015, 05:59 PM
GotMelon Re: How to: '00-'03 Grand... 06-27-2015, 01:29 PM
BrandonHall10 Re: How to: '00-'03 Grand... 06-27-2015, 01:37 PM
GotMelon Re: How to: '00-'03 Grand... 06-27-2015, 01:46 PM
GotMelon Re: How to: '00-'03 Grand... 07-21-2015, 10:29 PM
BrandonHall10 Re: How to: '00-'03 Grand... 07-21-2015, 11:01 PM
HighOctaneRacing Re: How to: '00-'03 Grand... 07-22-2015, 07:51 AM
GotMelon Re: How to: '00-'03 Grand... 07-22-2015, 03:36 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-22-2015, 06:27 PM
GEMINIokc Re: How to: '00-'03 Grand... 07-23-2015, 05:25 AM
GEMINIokc Re: How to: '00-'03 Grand... 07-23-2015, 05:23 AM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 07:48 AM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 12:36 PM
Bronco Boy Re: How to: '00-'03 Grand... 08-06-2015, 04:11 PM
CrazyGuy03 Re: How to: '00-'03 Grand... 07-23-2015, 08:08 AM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 08:09 AM
CrazyGuy03 Re: How to: '00-'03 Grand... 07-23-2015, 08:13 AM
BrandonHall10 Re: How to: '00-'03 Grand... 07-23-2015, 08:16 AM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 08:21 AM
CrazyGuy03 Re: How to: '00-'03 Grand... 07-23-2015, 08:27 AM
JamesIvey24 Re: How to: '00-'03 Grand... 07-23-2015, 08:49 AM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 09:14 AM
Bronco Boy Re: How to: '00-'03 Grand... 07-23-2015, 09:19 AM
HighOctaneRacing Re: How to: '00-'03 Grand... 07-23-2015, 11:15 AM
Bronco Boy Re: How to: '00-'03 Grand... 07-23-2015, 11:33 AM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 12:38 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 12:40 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 12:41 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 12:44 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 12:47 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 12:52 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 12:55 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-23-2015, 12:56 PM
J57ltr Re: How to: '00-'03 Grand... 07-23-2015, 01:58 PM
CrazyGuy03 Re: How to: '00-'03 Grand... 07-23-2015, 01:05 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 01:05 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 02:04 PM
J57ltr Re: How to: '00-'03 Grand... 07-23-2015, 02:18 PM
Booba5185 Re: How to: '00-'03 Grand... 07-23-2015, 09:43 PM
CrazyGuy03 Re: How to: '00-'03 Grand... 07-23-2015, 10:17 PM
Booba5185 Re: How to: '00-'03 Grand... 07-24-2015, 12:09 AM
GotMelon Re: How to: '00-'03 Grand... 07-26-2015, 06:37 PM
Bronco Boy Re: How to: '00-'03 Grand... 07-29-2015, 04:00 PM
BrandonHall10 Re: How to: '00-'03 Grand... 07-29-2015, 04:45 PM
Bronco Boy Re: How to: '00-'03 Grand... 07-29-2015, 04:58 PM
ADrugDealer Re: How to: '00-'03 Grand... 07-29-2015, 11:17 PM
buford1972 Re: How to: '00-'03 Grand... 07-30-2015, 03:22 AM
Booba5185 Re: How to: '00-'03 Grand... 08-06-2015, 05:58 PM
sparkydog Re: How to: '00-'03 Grand... 02-16-2016, 09:49 PM
Bronco Boy Re: How to: '00-'03 Grand... 02-17-2016, 10:46 AM
sparkydog Re: How to: '00-'03 Grand... 02-17-2016, 09:23 PM
Bronco Boy Re: How to: '00-'03 Grand... 02-18-2016, 09:55 AM
REDCRAPGP Re: How to: '00-'03 Grand... 02-17-2016, 09:24 PM
SubwayGuy Re: How to: '00-'03 Grand... 02-18-2016, 09:59 AM
Brangeta Re: How to: '00-'03 Grand... 05-19-2021, 11:48 AM
Bronco Boy Re: How to: '00-'03 Grand... 07-23-2015, 10:19 PM
  1. #1 How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Mar 2014
    Tucson
    Here's how I added a standalone transmission cooler to my '00 Grand Prix. From what I understand, some '99s, and all '00 thru early '04's are unique in that they have an "external" check valve in the cooler feed fitting. So we are required to use this check-ball fitting in anything we do. So here's what I did based on a couple criteria:
    1.) It had to work. If it didn't keep the fluid cooler, or it leaked, it was pointless.
    2.) It had to look good. No hack job. I'm a professional.... Kinda.
    3.) No hose clamps, because... See 1 and 2.
    4.) I had to be able to revert back to stock fairly easily. I bought some extra cooler lines at the junkyard to hack up, and my original lines are sitting on a shelf.
    Here's a complete parts list;
    Hardware:
    6- 1/4"-20x3/4" Bolts
    2- 1/4"-20x1" Bolts
    5- 1/4" Flat washer
    8- 1/4"-20 Lock nut
    Support:
    1/16"x3/4"x36" Weld steel Local hardware store / Steel supply house
    Cooler:
    B&M Super Cooler # 70266 http://www.summitracing.com/parts/BMM-70266
    Lines:
    1- -6an x 3' ready made hose* http://www.jegs.com/i/JEGS-Performan...10613/10002/-1
    1- -6an x 4' ready made hose* http://www.jegs.com/i/JEGS-Performan...10614/10002/-1
    Fittings:
    1- -6an x 1/2" NPT 90° http://www.jegs.com/i/JEGS-Performan...10159/10002/-1
    1- -6an x 1/2" NPT http://www.jegs.com/i/JEGS-Performan...10119/10002/-1
    2- -6an x 3/8" NPT http://www.jegs.com/i/JEGS+Performan...10106/10002/-1
    2- 3/8" Tube (Compression) x 3/8" FIP 90° Hardware store / Plumbing supply house
    2- 3/8" NPT plugs (to plug old cooler holes in radiator)
    I chose to splice into the factory lines where I did, because I wanted to retain the factory cooler line support on the transmission. I didn't want the weight of the cooler line hanging off that quick disconnect fitting. The only thing not shown here is the pipe plugs in the radiator to block off the old cooler.
    Everything laid out. An "exploded" view:
    Here's the cooler mounted to the radiator support:
    The clearance required for the support in the left air inlet duct:
    The clearance required for the upper elbow in the air baffle:
    The clearance required for the hoses in the radiator support:
    The clearance required for the hoses in the air baffle:
    Compression fittings in a different location than shown in the layout view.
    Assembled view from top:
    Assembled view from bottom:
    Standard 3/8" NPT brass pipe plugs
    Installed
    *After getting everything assembled, I ended up with about a foot extra on each hose. Knowing what I know now, I would order a 2' and 3' ready made hose. The little difference from the custom cut length wouldn't be a problem. The lengths of the hose reflect the feed line supplying the bottom of the cooler and the return line coming from the top. This ensures no air in the cooler.
    Leftover hose
    Random pictures:
    Teardown
    Check ball "feed/supply" fitting
    3/8" Tube to -6an fitting
    Cooler hose laid out
    Cooler view looking up
    Assembled
    I won't know for sure how much of a difference this makes for a while, but I have to image it can only help out here in the southwest.
  1. 9C1 Transmission Cooler on Grand Prix
    By Impala131 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2014, 10:29 AM
  2. Trans stock cooler line replace/fluid loss?
    By spazzz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2014, 08:36 PM
  3. trans cooler line for my 2002 grand prix se 3.1 ?
    By philr roy in forum General Tech Discussion
    Last Post: 01-23-2013, 12:19 AM
  4. 04 grand prix gtp cooler lines
    By TheManInBlack in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-12-2012, 09:31 PM
  5. Adding Transmission Fluid - 05 Grand Prix
    By mpoynter31 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-09-2010, 05:12 PM
