Thread: How to: '00-'03 Grand Prix standalone transmission fluid cooler
Results 21 to 40 of 62
  1. #21 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Buffalo
    There is not one way to do it , but there is one way for each person - says unknown
  2. #22 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Mar 2014
    Tucson
    Using barbed fittings and hose clamps isn't the worst thing in the world. Just make sure you got good hose clamps.
    I think problems occur when people try to clamp rubber line directly to the smooth steel line, and it spits it right off.
  3. #23 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    Where winter never ends
    Well that's just stupid
    Sent from my VS986 using Tapatalk
    2000 Regal - Winter Beater
  4. #24 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Buffalo
    And yet people still do it ! (That's what I was referring to)
  5. #25 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    I wouldn't put anything or disturb anything in between the trans and the radiator line, as that is somewhat of a pressure line and I've seen and heard many issues, leaks, lines popping off, etc...and that goes for more than just these 3800 powered cars. Personally I wouldn't ever put a trans cooler in these cars, however...if a person would choose too, it's safer to insert it after the radiator, before the return side of the trans.
  6. #26 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    Quote Originally Posted by JamesIvey24 View Post
    Sorry but that is just ignorant. The GXPs bassically need a trans cooler to survive under abuse in stock form and anyone making any kind of power with an aftermarket torque converter needs one. I didn't have one of my Billet 3000 stall and the trans jumped to 260 in one pull. If done properly with hoseclamps and the right size barbs it will not leak.
  7. #27 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Jul 2010
    Coquitlam,BC,Canada
    Why not?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #28 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Enfield, CT
    Quote Originally Posted by Bronco Boy View Post
    Why not?
    He gave his reasons lol
    Sent from my LG G3
  9. #29 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Jul 2010
    Coquitlam,BC,Canada
    Why not?
    Quote Originally Posted by HighOctaneRacing View Post
    Just because a bunch of people did improper installs is not a valid reason to me. Thought there might be more to it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #30 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Feb 2013
    Missouri
    Quote Originally Posted by ADecker View Post
    I ran the hot fluid into the cooler, then into the stock cooler then into the trans
    From what I've read, that's backwards. You are reheating the fluid at that point. It should go Trans->stock cooler->external cooler->Trans. That way the coolest fluid goes back into the transmission.
    This is a super clean install though. If I lived back in a warmer climate I'd do this. I still might do this, only add in a thermostat...
  11. #31 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    That's the point. You want the fluid at around 180-190, the trans cooler will cool it a ton then the stock cooler will get it back to operating temp. Especially smart in cold states. Otherwise your running cold cold cold fluid forever
  12. #32 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Feb 2013
    Missouri
    I always went off of 175*F being the max I've hit 180*F once or twice. That's why I'm gonna go the thermostat route, nothing will go to either cooler until it gets to temperature.
  13. #33 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    Uhm... What? The trans doesn't have a Tstat? It's always pumping and cooling fluid.....
  14. #34 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Feb 2013
    Missouri
    You can add a thermostat to the cooling lines. I read about it over on FSB where guys have good luck with them. Not this exact one, but something of the sort:
    http://derale.com/products/fluid-coo...-chrome-detail
  15. #35 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    God no! Then you dont have fluid flow back to the transmission! Why make this complicated and mess with flow, go cooler then radiator. Problem solved. Unless your somewhere where its always hot, then just run the cooler
  16. #36 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    I see now it doesn't totally stop flow but still that would make me so nervous and is pointless
  17. #37 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Feb 2013
    Missouri
    The thermostat I'm talking about just loops it back into the transmission until it reaches temperature then it goes onto the coolers. I'm wanting to try it out just to see how it works, and for a few other reasons. I monitor everything very closely so we'll see what happens. I might have the thermostat put in between the radiator's cooler and the external cooler. That way it's always got at SOMETHING if the thermostat fails.
    Edit: I didn't see the second post. If I could find somewhere to mount it, there are oil filter adapters that have thermostats built in. I was hoping to find somewhere to put it, I dunno. Then I'd have the thermostat, external filter, and the cooler.
  18. #38 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    May 2012
    You have no way to monitor line pressure .... so if that thing doesn't allow enough fluid back good luck with the rebuild. The transmission fluid is the life blood.
  19. #39 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Buffalo
    By pass valve to aux cooler
  20. #40 Re: How to: '00-'03 Grand Prix standalone transmission fluid cooler
    Feb 2013
    Missouri
    I don't mind rebuilding it. I've been planning it for awhile. These are designed for this use so I don't see it being a problem. Hayden has one like the one linked, but I'm thinking I'll start looking for a place to mount one that has a oil filter and a thermostat...once I find one, lol.
  1. 9C1 Transmission Cooler on Grand Prix
    By Impala131 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2014, 10:29 AM
  2. Trans stock cooler line replace/fluid loss?
    By spazzz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2014, 08:36 PM
  3. trans cooler line for my 2002 grand prix se 3.1 ?
    By philr roy in forum General Tech Discussion
    Last Post: 01-23-2013, 12:19 AM
  4. 04 grand prix gtp cooler lines
    By TheManInBlack in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-12-2012, 09:31 PM
  5. Adding Transmission Fluid - 05 Grand Prix
    By mpoynter31 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-09-2010, 05:12 PM
