I just thought I’d share my noisy power steering pump story for anyone who might be interested/affected. Just for a little back ground, the pump started to make a noticeable amount of noise last winter. So I checked the fluid level, then I didn’t concern myself with it. This summer it would intermittently growl at me, and then after a couple minutes of driving it would be quiet again not a big deal. It recently came to a head when I was carting around a buddy of mine (whom also is a GP fan) and he’s like “you’re low on fluid manâ€. Being a maintenance freak, I was a little embarrassed and told him it’s not low the pump is just a little noisy today.But that it got me thinking maybe I should just change out the fluid, even though the noise did start when the car was nearly new.
So I went to work with some Prestone power steering fluid and a turkey baster. Cutting to the chase the fresh fluid cured the noisy pump, and has made me a happy camper. The rest of this is a how to for the non-motor heads out there.
The power steering pump buried under the alternator. I first moved the coolant reservoir out of the way, it is only held down by (2) 10mm nuts. Now that I could clearly see the steering pump, I removed the cap and used the baster to get out as much fluid as I could. I managed to remove about 8 ounces, and it looked really dirty kind of like used engine oil.Then I cleaned off the baster and also used it to put the new fluid in. After filling it to between the cold-hot markers on the cap dip stick, I secured the cap and started the car. After moving the steering wheel side to side a couple times the power steering pump was still pretty noisy. I turned the car off, and proceeded to exchange another 8 ounces of fluid. This time around I discovered the bottle of power steering fluid can be set right next to the oil filter/power steering pump for easy access.
Also, I put all my waste fluid into an empty windshield washer container. After the second exchange the pump has been very quiet, it is like I’m driving a different car.
