Normally when you turn your brights on, the fogs will shut off. This lets them stay on when you turn on the brights. More lights = more light.
'98 Fog Lights with High Beams Modification
I'm a little confused as to what they're saying the fog light switch will do. If I understand correctly, they're saying the fog light switch will work correctly as usual but when you turn the brights on, the indicator turns off. With his "preferred method," does it work normally all the time, or is it making it so the indicator is always on?Anyone wanna clarify that one for me?
