Thread: figuring out if your cat is clogged
Results 1 to 10 of 10
Threaded View
  1. #1 figuring out if your cat is clogged
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    this is a how to, to see how to figure out if your catalaytic conveter is clogged,
    1st, pull the o2 sensor the one on the rear exhaust manifold
    2nd, then take it for a ride with it out
    3rd, if you have your power back this is your problem,you need a cat
    4th,go get / buy a cat
    5th just cuz it dont make any sounds wen you tap on the cat does not mean its good, and it will not be glowing red thats only if its not runnin rite dumping raw fuel in the converter
    might be not be amussing but will help alot ppl out ive been doin it this way for over 12yrs now, im a ase certified mechanic, using a back pressure tester half of the tyme will not tell you if the cat is partially clogged. i hope this can help alota ppl out , pic below was my partially clogged cat would not excelerate and was bucking and had all cylinder missfires data codes p0300
  1. I need help figuring out what this part is called
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 02:17 PM
  2. Clogged cat, bad o2?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 01:38 PM
  3. need some figuring out my '98 dakota
    Last Post: 05-02-2009, 11:41 PM
  4. Replies: 10
    Last Post: 04-04-2009, 11:02 PM
