Thread: Is your ABS and TCS light on? This should help!
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Is your ABS and TCS light on? This should help!
    Mar 2014
    Tucson
    Mine ended up being the EBTCM. Sent it out for a rebuild. Now all is well.
  2. #22 Re: Is your ABS and TCS light on? This should help!
    Apr 2014
    CT
    I peeled back the wire loom off the harness between the knuckle and lower control arm. It only takes a few minutes to pull it off. If the wires broke you will see the hard plastic covering or whatever that crap is on the wires busted up right away. I didn't replace it. I just soldered it. The wire was pretty corroded but I used some contact cleaner to get the wire in good enough shape for solder to stick to.
  3. #23 Re: Is your ABS and TCS light on? This should help!
    Jun 2013
    Hollywood ,FL
    Decent hub to buy? Cheapy ebay ones?
  4. #24 Re: Is your ABS and TCS light on? This should help!
    Yea.. If you want to keep on replacing it... Better stick to something like timken/Moog etc that has a 3 year warranty and grab it locally so exchanging to isn't a hassle.
    04 Comp G.
  5. #25 Re: Is your ABS and TCS light on? This should help!
    Jun 2013
    Hollywood ,FL
    Gotcha thanks
  6. #26 Re: Is your ABS and TCS light on? This should help!
    SWPA
    Quote Originally Posted by stu259 View Post
    my quick check on wheel bearings, grab the top of the wheel(car on the ground) and shake it toward you then away. if there is any play, bad bearing. If you can't move the tire go inside and find your big boy pants, and try again. if there is no play your good to go!!
    Not always. I had zero play in a bad bearing before.
  7. #27 Re: Is your ABS and TCS light on? This should help!
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    how about not having an abs light on at all (no the bulb isnt blown or missing) but TCS light is always illuminated showing "tcs off" and pushing the button on the dic does nothing?
    2001 Grand Prix GTP, silver w/ black hood, silver bullit 17s
  8. #28 Re: Is your ABS and TCS light on? This should help!
    SE Level Member powerdpower's Avatar
    Dec 2014
    Brigham City, Utah
    Quote Originally Posted by jjmitch87 View Post
    I am having this same issue. It would be nice to have some insight into it, although it is still probably going to be a bearing..
  9. #29 Re: Is your ABS and TCS light on? This should help!
    Palmdale
    So thereS a wire for each side right? The person who owned the car before decided to cut the wire on the pass anger side and I have no idea where on loom this wire sits.. can anyone take a picture e of theirs or tell me where I can finds this wire. My TCS/ and ABS lights have been on since I got .. I have replaced the wheel bearings already
  10. #30 Re: Is your ABS and TCS light on? This should help!
    Mar 2015
    USA
    Quote Originally Posted by dmack976 View Post
    There is a bracket right behind the brake rotor that holds the connector. From there is runs along the a arm, then up into the wheel well. (Take the plastic splash cover off). The pass side runs up to, and along the top of the engine cradle.
    I can't speak for the drivers side, my pass side harness was bad, and the drivers side hub was bad.
    Key on, engine off unplug the connectors. You should see close to 5v between the two pins coming from the car harness.
    You can also switch your meter to ohms and measure the two pins looking at the hub. You should have some resistance (I forget the value). But if you see an open circuit there, then it's the hub that is bad.
    The factory piece is 2 wires, inside of plastic tube, inside wire loom. Once I pulled back the wire loom, I found the bad spot. It seems like that factory plastic tube holds moisture in, gets brittle and causes problems.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
