Thread: Is your ABS and TCS light on? This should help!
Results 1 to 20 of 30
  1. #1 Re: Is your ABS and TCS light on? This should help!
    Feb 2014
    Mi
    My is messed up to I had new bearing put on but still have the abs and tc light on is it pretty easy to put a new wire harness on????
  2. #2 Re: Is your ABS and TCS light on? This should help!
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    I have an abs issue, but Im pretty certain its not my hubs as they all spin nicely. I sure hope its as simple as a broken/grounded wire and not the module itself.. Fyi you can't remove a wheel with a tie rod, nor can you spin a caliper .
  3. #3 Re: Is your ABS and TCS light on? This should help!
    May 2012
    NW lower Mi.
    my quick check on wheel bearings, grab the top of the wheel(car on the ground) and shake it toward you then away. if there is any play, bad bearing. If you can't move the tire go inside and find your big boy pants, and try again. if there is no play your good to go!!
  4. #4 Re: Is your ABS and TCS light on? This should help!
    SWPA
    Quote Originally Posted by stu259 View Post
    Not always. I had zero play in a bad bearing before.
  5. #5 Re: Is your ABS and TCS light on? This should help!
    Apr 2014
    CT
    I peeled back the wire loom off the harness between the knuckle and lower control arm. It only takes a few minutes to pull it off. If the wires broke you will see the hard plastic covering or whatever that crap is on the wires busted up right away. I didn't replace it. I just soldered it. The wire was pretty corroded but I used some contact cleaner to get the wire in good enough shape for solder to stick to.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
