my quick check on wheel bearings, grab the top of the wheel(car on the ground) and shake it toward you then away. if there is any play, bad bearing. If you can't move the tire go inside and find your big boy pants, and try again. if there is no play your good to go!!
Not always. I had zero play in a bad bearing before.
