Thread: Crankshaft Position Sensor Replacement [*]
Results 1 to 20 of 84
SyntheticShield Crankshaft Position Sensor... 01-04-2008, 12:17 PM
SyntheticShield For all you linguistic purist... 01-04-2008, 12:18 PM
IndeedSS excellent write-up 01-04-2008, 12:35 PM
MTXGTP great write up yea dont use... 01-04-2008, 12:27 PM
UR LOSN I here by give this write up.... 01-04-2008, 01:37 PM
SyntheticShield Im glad UR LOSN posted... 01-04-2008, 01:58 PM
DuBob FYI, it's 22 foot lbs on... 01-04-2008, 02:58 PM
SyntheticShield Good. I knew someone would... 01-04-2008, 03:09 PM
TyroElite awesome writeup! Nice job... 01-04-2008, 07:34 PM
Reptile Nice writeup you got there... 01-04-2008, 11:15 PM
SyntheticShield Yep finally in 20mph winds... 01-05-2008, 12:22 AM
J_Ferguson WTG Awsome write up Scotty 01-05-2008, 12:41 AM
Toasty Re: Crankshaft Position... 01-30-2008, 02:04 AM
02BlueGT Re: Crankshaft Position... 01-30-2008, 04:12 AM
SyntheticShield Re: Crankshaft Position... 01-30-2008, 02:55 PM
SyntheticShield Re: Crankshaft Position... 01-30-2008, 02:56 PM
Toasty Re: Crankshaft Position... 01-30-2008, 04:48 PM
SyntheticShield Re: Crankshaft Position... 01-30-2008, 05:02 PM
TMC Re: Crankshaft Position... 12-10-2008, 12:11 AM
spenc938 Re: Crankshaft Position... 12-17-2008, 09:30 PM
JennJenn85 Re: Crankshaft Position... 03-23-2009, 08:46 AM
LOUDANDPROUDGTP Re: Crankshaft Position... 07-19-2009, 01:32 PM
elks Re: Crankshaft Position... 06-28-2012, 12:07 AM
GTP PRIX Re: Crankshaft Position... 08-06-2012, 07:59 PM
Y2KGTP Re: Crankshaft Position... 05-16-2010, 11:09 PM
SyntheticShield Re: Crankshaft Position... 12-17-2008, 10:36 PM
slsmith1959 Re: Crankshaft Position... 11-13-2010, 07:41 PM
SyntheticShield Re: Crankshaft Position... 03-23-2009, 09:32 AM
Panto911 Re: Crankshaft Position... 05-22-2009, 01:39 AM
spenc938 Re: Crankshaft Position... 05-22-2009, 06:04 PM
offroadfury6 Re: Crankshaft Position... 07-20-2009, 02:16 AM
GTPrix Re: Crankshaft Position... 07-24-2009, 04:12 PM
03GPScottyd Re: Crankshaft Position... 03-05-2010, 01:30 PM
camcavoy Re: Crankshaft Position... 03-22-2010, 09:43 AM
pacothetaco Re: Crankshaft Position... 05-17-2010, 05:07 PM
bankai Re: Crankshaft Position... 06-27-2010, 08:21 PM
cgp Re: Crankshaft Position... 01-12-2012, 11:36 AM
BillBoost37 Re: Crankshaft Position... 01-12-2012, 11:42 AM
cgp Re: Crankshaft Position... 01-13-2012, 11:32 AM
cgp Re: Crankshaft Position... 01-20-2012, 08:53 PM
Panthers144 Re: Crankshaft Position... 03-05-2012, 10:10 AM
BillBoost37 Re: Crankshaft Position... 03-05-2012, 10:23 AM
ricksgpgtcolleen Re: Crankshaft Position... 06-21-2012, 08:04 PM
Scottydoggs Re: Crankshaft Position... 06-21-2012, 08:07 PM
BillBoost37 Re: Crankshaft Position... 06-22-2012, 05:34 AM
matt5112 Re: Crankshaft Position... 06-22-2012, 07:53 AM
bassamore Re: Crankshaft Position... 06-28-2012, 12:07 AM
KeithGTP03 Re: Crankshaft Position... 08-06-2012, 08:04 PM
GTP PRIX Re: Crankshaft Position... 08-07-2012, 11:57 PM
GTP PRIX Re: Crankshaft Position... 08-07-2012, 11:41 PM
KeithGTP03 Re: Crankshaft Position... 08-07-2012, 11:43 PM
Fivefingerdeathpunch Re: Crankshaft Position... 08-07-2012, 11:43 PM
Fivefingerdeathpunch Re: Crankshaft Position... 08-07-2012, 11:58 PM
00grandprixgtp Re: Crankshaft Position... 08-08-2012, 12:02 AM
Fivefingerdeathpunch Re: Crankshaft Position... 08-08-2012, 12:05 AM
GazV6GT Re: Crankshaft Position... 04-23-2013, 11:10 AM
BillBoost37 Re: Crankshaft Position... 04-23-2013, 11:32 AM
ericspecullaas Re: Crankshaft Position... 04-23-2013, 03:07 PM
GazV6GT Re: Crankshaft Position... 04-23-2013, 04:57 PM
REDCRAPGP Re: Crankshaft Position... 04-23-2013, 05:03 PM
GazV6GT Re: Crankshaft Position... 04-23-2013, 05:45 PM
REDCRAPGP Re: Crankshaft Position... 04-23-2013, 05:55 PM
BillBoost37 Re: Crankshaft Position... 04-24-2013, 06:57 AM
GazV6GT Re: Crankshaft Position... 04-24-2013, 04:22 PM
98GPree Re: Crankshaft Position... 04-26-2013, 08:49 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 09:26 AM
98GPree Re: Crankshaft Position... 04-26-2013, 09:35 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 09:39 AM
98GPree Re: Crankshaft Position... 04-26-2013, 09:43 AM
98GPree Re: Crankshaft Position... 04-26-2013, 09:44 AM
Scottydoggs Re: Crankshaft Position... 04-26-2013, 09:48 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 09:50 AM
98GPree Re: Crankshaft Position... 04-26-2013, 09:52 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 09:54 AM
98GPree Re: Crankshaft Position... 04-26-2013, 10:39 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 10:54 AM
Scottydoggs Re: Crankshaft Position... 04-26-2013, 10:58 AM
BillBoost37 Re: Crankshaft Position... 04-26-2013, 10:53 AM
Scottydoggs Re: Crankshaft Position... 04-26-2013, 10:57 AM
98GPree Re: Crankshaft Position... 04-26-2013, 04:52 PM
JStump Re: Crankshaft Position... 11-22-2014, 04:04 PM
Scottydoggs Re: Crankshaft Position... 11-22-2014, 04:07 PM
JStump Re: Crankshaft Position... 11-23-2014, 12:54 AM
  1. #1 Re: Crankshaft Position Sensor Replacement [*]
    Oklahoma
    You're more than welcome.
  2. #2 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2008
    as
    SyntheticShield, I had a question.
    I'm a little confused on the step where you said to, "Clamp a pair of good heavy duty vice grips on the flywheel towards the front side of the engine."
    I was going to attempt this later today and want to know exactly how and why to do this? thanks in advance.
  3. #3 Re: Crankshaft Position Sensor Replacement [*]
    Feb 2008
    West Jordan, UT
    Quote Originally Posted by Panto911 View Post
    You do this to prevent the crank from spinning when you're trying to remove the harmonic balancer bolt.
    If you look at this picture you can see exactly where to put it under the car.
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
