Thread: How-to change lower control arms
Page 4 of 4 FirstFirst ... 234
Results 61 to 76 of 76
  1. #61 Re: How-to change lower control arms
    SE Level Member fmayo's Avatar
    massachusetts
    Quote Originally Posted by tdm571 View Post
    I was able to cut thru the bolt. I only dulled two blades. The size of the bolt is M14-2.00 90mm. I used a metric 10.9 grade bolt which is the equivalent of a grade 8. I also decided to upgrade the sway bar while I was at it. There's a huge difference in the tightness of the steering. Glad I did it.
    I got lucky with the PB Blaster I guess, the torx bolts came out without too much trouble. I did pick up new bolts before hand though but had trouble finding metric bolts in my area. Ended up using a 9/16" x 4" #8 bolts to replace the torx bolt. Make sure you get some good washers too so the hex head doesn't cut into the aluminum sub-frame.
  2. #62 Re: How-to change lower control arms
    Oct 2011
    Toledo, OH
    8. Put new lca in place and put the new nut that comes with it on the ball joint.
    Thanks for the write-up. Just wondering if there is any reason to not re-use your factory nuts if they are in good condition? I noticed the OEM nuts are flanged, and the Dorman ones are not.
    7"
  3. #63 Re: How-to change lower control arms
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Quote Originally Posted by industrialfish View Post
    I did not re-use any nuts.
    Edit: There is no reason to
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #64 Re: How-to change lower control arms
    No reason other than the old ones like to round off sLightly sometimes
  5. #65 Re: How-to change lower control arms
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    Why isn't there any talk of TTY tightening?
  6. #66 Re: How-to change lower control arms
    What tty?
  7. #67 Re: How-to change lower control arms
    Because nobody cares about torque to yield bolts??
    I never replace bolts unless this is something like head bolts or something critical.
  8. #68 Re: How-to change lower control arms
    Oct 2011
    Ohio
    Yes, was trying to say "never mind", but the server was too busy to log in. I see this isn't critical in this situation. Found out this by looking up replacing a Focus' LCA. Their balljoint stud is held in by clamping friction (no nut), although the video wasn't TTYing that bolt (lol). Thanks.
  9. #69 Re: How-to change lower control arms
    Oct 2011
    Ohio
    Torque-to-yield. I'll just link you Wiki.
    https://en.m.wikipedia.org/wiki/Torq...yield_fastener
  10. #70 Re: How-to change lower control arms
    Yeah none of these are tty
  11. #71 Re: How-to change lower control arms
    Apr 2014
    commerce twp,mi
    bumpin this to say thanks for the write up. i sometimes wonder how much time i would have saved 20-30 years ago if i had the net back then.
    one note- the 21mm wrench makes the job a lot easier. my set skipped 21 but i managed with a cresent but would have been a lot easier with that.
    another note:
    make sure ya have all the tools BEFORE starting the job.
  12. #72 Re: How-to change lower control arms
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Helped to know the sizes. Went quicker that way.
    If any of these are TTY bolts, I'd be thoroughly flabbergasted.
  13. #73 Re: How-to change lower control arms
    Oct 2011
    Ohio
    Since it was the first I heard of it (especially in suspension parts (Ford)), I was a bit taken. Since, considering clamping force and vibration, I thought it was critical. Now, I think it is important, but not critical, especially considering material inconsistency and thread-hangup.
    After doing one, I think I measured the torque afterwards; I can't clearly remember what happened, but I think it was a few pounds past the torque specification. I don't know why the straight torque (with tolerance) isn't sufficient in these applications -- so, that is my personal summation. Plus, I don't think a gauge is quite necessary - just observation of the angle turned-through.
  14. #74 Re: How-to change lower control arms
    Jan 2021
    Ohio
    Shouldn't I jack up the lower control arm so the arm is close to where the arm sits when the car is sitting on the ground, and then tighten my control arm bushings?
  15. #75 Re: How-to change lower control arms
    Sep 2014
    Worcester, MA
    That's the proper way to do it, yes.
    I like to install everything, but wait for the final tightening until it's all together (and ideally supported). But honestly sometimes I have skipped the step to support it before final tightening and so far so good.
    -Bob C.
  16. Likes mrbreezeet1 liked this post
  17. #76 Re: How-to change lower control arms
    Jan 2021
    Ohio
    Sorry I didn't get a notification.)
    Thanks.
    Good to know it didn't hurt the bushings.
  1. Replacing lower control arms
    By Linebacker in forum General Tech Discussion
    Last Post: 08-01-2021, 05:53 PM
  2. 2004 GT2 Lower Control Arms
    By apok in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2012, 10:21 PM
  3. 97-03 vs 04+ lower control arms
    By Wicked13 in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 10:17 PM
  4. Lower Control Arms
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:55 PM
